dana 30 inner axle shaft seal replacement? - JeepForum.com
post #1 of 4 Old 04-07-2009, 11:02 AM Thread Starter
DeadPhish
1977 CJ7
i ordered the inner axle shaft seal to replace while i am replaceing all the bearings on the hub and spindle. What i didnt realize was that these were located inside the tubes all the way down near the pinion. how much trouble are these to replace. I wasnt looking to replace anything in the pumpkin.
DeadPhish is offline
post #2 of 4 Old 04-07-2009, 01:12 PM
cjgator
1979 CJ5
Getting the seals out is a little bit of a PIA as the out board side of the seals are rounded over, you'll see what I mean when you get the new seals. This makes getting a seal puller behind them more difficult. I had to carefully bend up the inside lip of the seal to free them up enough to pull out. Not being able to get a good angle didn't make it any easier. I don't see much problem installing them though.
cjgator is offline
post #3 of 4 Old 04-07-2009, 09:20 PM Thread Starter
DeadPhish
1977 CJ7
getting the old out was not so bad getting the new ones in well lets just say after the 3rd damaged seal i gave up and took it to my local powertrain shop
post #4 of 4 Old 04-08-2009, 02:03 AM
gojeepgo
1981 CJ7
I have a set of these in the garage. I dont even have a dana 30 anymore. I bought them when rebuilding my old 30. After seeing what a pita they would be to replace I left the old ones in. They never failed on me. Unless they are bad I would not bother changing them out.
gojeepgo is offline
Rear Axle Seal Replacement? cjwdzr Jeep CJ Forum 0 05-13-2009 09:37 AM
dana 30 axle seal JKM3134 Jeep CJ Forum 1 05-04-2009 06:11 AM
CJ7 Rear Axle Seal Replacement cjwdzr Jeep CJ Forum 3 05-01-2009 10:08 AM
Rear Axle Seal Replacement 84 CJ7 Jeep CJ Forum 7 06-09-2008 04:30 PM
axle bearings and seal replacement for D44 Blackjackbender Jeep CJ Forum 4 11-19-2005 05:55 PM
