Dana 30 holding up to 34x9.50 LTB's? - JeepForum.com
post #1 of 14 Old 11-17-2011, 12:17 PM Thread Starter
Strings72
Hey all, it the midst of building my 82cj, Im swapping a a ford 9in. in to the rear and putting a T-18 behind the 258. When my 31's wear out (MT Baja Claws) Id like to get 34x9.50 SS LTB's. My question is how well can my stock wide track Dana 30 (will have 4.11's and 6bolt lockouts) hold up to these Tires? I know if you drive easy enough anything will last but im wondering if the tire gets in a bind if ill be busting shafts and U-joints. If it wont last is it worth it to swap in the dana 44 I have from the early bronco that I got the nine inch from?
Thanks
Marc
03 TJ: constantly evolving
06 Dodge 2500 CTD 6spd 4x4
Check out my build:
Strings72 is offline
post #2 of 14 Old 11-17-2011, 12:27 PM
addicted2dunes
1981 CJ8
I'd swap in the 44 no questions asked if it's just sitting there and all it needs is labor.
Cameron Gunlock
1981 CJ8 -
http://www.facebook.com/pages/Central-Coast-Krawlers/139075302856004
addicted2dunes is offline
post #3 of 14 Old 11-17-2011, 12:30 PM
98blacksahara
1951 CJ3A
as long as you aren't really heavy on the skinny pedal, you should be ok. I have a friend who wheels a commanche pickup on 37 inch boggers on a TJ D30. While the 2 axles are different, they are similar in strength.
But if you already have the 44, and the ability to swap it correctly, why not start with a better axle for future mods.
Originally Posted by RubiconRazorbac View Post
Well, I've never eaten a turd sandwich, but I wouldn't have a problem recommending not to try it.:thumbsup:
But I'm sure someone out there will post that they regularly eat turd sandwiches with no problems...
98blacksahara is offline
post #4 of 14 Old 11-17-2011, 12:41 PM
Bojeepus
the 34x9.50 cant be any diffrent than the 33X12.50 ive been running for the last 10 years in my yj, i havent broke yet
Bojeepus is offline
post #5 of 14 Old 11-17-2011, 12:52 PM Thread Starter
Strings72
the only thing to be said is the I already have a 4.11 ring and pinion for the D30 (bought wrong RP for my Tj) But I could leave the the 9in./D44 combo at 3.55's if you guys thimk that would be a low enough gear?
Check out my build:
post #6 of 14 Old 11-17-2011, 01:01 PM
98blacksahara
1951 CJ3A
Personally, I would want a bit lower than 3.55's with 34's. Ring and pinions are cheap in the grand scheme of things. I would really think about your intended use and future intended use. For mild to moderate trail riding, the 30 will be fine. If you are planning on trying to do more hardcore rock crawling like things with it, you may have issues depending on driving style.
How you drive is as important as what you drive, and whats under it.
post #7 of 14 Old 11-17-2011, 01:08 PM
backwoodboys11
1982 CJ5
I have run 44s on a Dana 30 front with no problems. The transfer case give up. It was with a ford 300 Inline 6.
Sent from my DROID3 using JeepForum
Big Daddy Slap-A-Hoe
backwoodboys11 is offline
post #8 of 14 Old 11-17-2011, 05:10 PM
jeepwhore
Along with driving style and terrain, the other thing that will affect the length of the 30's life is if you lock it or not.
An open diff D30 will typically live longer than a locked one especially in more technical terrain. In mud, sand and mild trails the locker is a definite bonus and longevity isn't much of a concern. But in the rocks and technical stuff the locker is more likely to cause breakage (especially if the wheels are turned) and leave you busted in the toolies. Obviously the driving style thing affects how likely this is to happen but it is something to remember when you're out there.
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #9 of 14 Old 11-17-2011, 05:19 PM Thread Starter
Strings72
I was going to run an Aussie locker in either axle
Check out my build:
post #10 of 14 Old 11-17-2011, 05:31 PM
jeepwhore
Well then I'd say yes, if you bind up a tire with a locker in there you'll probably end up with some sort of carnage. Like I mentioned, that typically happens with the tires turned and/or one of them wedged in an obstacle.
It sounds like you're planning to be in terrain where that could happen so I'd just go with the 44.
post #11 of 14 Old 11-17-2011, 06:30 PM
98blacksahara
1951 CJ3A
Breakage usually occurs at the u-joint in a front axle application. Whether from the caps walking or popping out, or the joint itself failing. Most (not all) D44's that come out of a early bronco run the spicer 260x joint which is the same size as the D30 in most jeeps.
The gain in shaft strength stock for stock is marginal. Ring and pinion strength and housing strength are where the benefits are.
Now if aftermarket shafts, carriers and the like come n to play, the D44 gets the nod hands down.
post #12 of 14 Old 11-17-2011, 07:04 PM
TPSreports
1983 CJ7
I would swap the Ford 9" rear but not the front 44. The early Bronco 44's have a drivers side drop and your dana 30 is passeneger side. Front 44's from a Chevy, 80's and up FSJ's, and Scouts are passenger side drop and a better candidadte for a CJ in my experience.
With light to moderate trail use, you should be fine on your dana 30 with 34's. If you plan to wheel pretty hard and beat on it, a front 44 would be a better choice for sure.
1983 CJ-7 Laredo Jasper 258, Clifford intake/hedder, MC2100, HEI, MSD digital 6al. Warner T5, Dana 300, Dana 30/Ford 8.8 SOA, 33x12.50 Goodyear MTR
1999 XJ Cherokee Classic
2001 XJ Cherokee Limited
TPSreports is offline
post #13 of 14 Old 11-17-2011, 07:10 PM
98blacksahara
1951 CJ3A
For the amount of work it will take to make the EB D44 fit, just run the D30 with the gears you already have. If you start breaking things, consider an upgrade at that time.
The problem with all the magazine and tv build lately is that now everyone thinks they need huge axles or they will grenade turning into a spot at the grocery store. Most people do not need more than a mildly upgraded stock axle if they really, honestly admit to their actual intended use.
Run the 30, if it breaks, upgrade, or swap it out. If it doesn't break, then you saved a bunch of money and can get other upgrades
post #14 of 14 Old 11-17-2011, 10:23 PM
jeepwhore
True, the locking hubs and u-joints are often the first point of failure. Interseting about the small u-joints, I didn't know most had the smaller ones....and for some reason thought those axles were pass. drop. That all said, that particular 44 doesn't seem worth the hassle of swapping.
76' CJ7 Not Holding the Road AUSHii Jeep CJ Forum 7 09-27-2009 09:42 AM
AMC 401 not holding oil pressure wyocj Jeep CJ Forum 6 03-01-2009 06:45 PM
34" Tires, TSL's or LTB's sweetguardian00 Jeep CJ Forum 12 02-10-2009 08:08 PM
What would it take to run 34x9.5 TSL's? sweetguardian00 Jeep CJ Forum 8 05-14-2008 08:10 PM
AMC 20- What is holding these axles in?? hfjeff Jeep CJ Forum 20 03-29-2007 11:11 PM
