DANA 30 Gears.. 1.73:1??? what's up with this.. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > DANA 30 Gears.. 1.73:1??? what's up with this..
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 06-04-2002, 07:47 PM   #1
DingoCJ5
Angry DANA 30 Gears.. 1.73:1??? what's up with this..
I have a 78 cj5 with 3.54 locked rear and what appears to be a 1.73:1 open front dana 30.. how could this be.. it's quiet .. is it possible to mix and match gears to get wrong ratios?? i shutter at the 600 dollar replacement cost to get my 3.54 front.. but the dana 30 can't go below 2.73... !!???!??!?
any hints..
clues ideas
jokes??
78 cj5 304
DingoCJ5 is offline   Reply With Quote Quick reply to this message
Unread 06-04-2002, 09:22 PM   #2
G Beasley
Post
I have a 3.54 frnotn with disc bakes for 250.00 .Shipping would be around 100.00 .Sometimes when previous owners break things they end up settling for any front or rear that will bolt it .They usually forget to mention to you as you are driving away that the ratios dont match .It seems half the jeeps I buy to part out dont have matched gears .But in regards to a 1.73 it should b e a 2.73 still a worthless gear. Does a 1.73 exist for a dana 30 ??? Hope this helps .
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 06-04-2002, 11:35 PM   #3
jeepdaddy2000
1971 CJ5
Post
When in doubt, pop the lid and do a tooth count. Divide the number of teeth on the ring by the number on the pinion.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2002, 07:33 AM   #4
G Beasley
Post
You dont have to count the teeth .The ratio numbers are stamped in the ring gear .Just pop the cover and spin the front til you see the #s .
Dingo I will get back to you tonight about shipping
