Dana 30 disc brake conversion with quadtratrac/open to suggestions - JeepForum.com
post #1 of 4 Old 09-11-2012, 08:54 AM Thread Starter
chrbone
1976 CJ7
I am a newbie and have limited mechanical knowledge. I am very slowly restoring a 76 CJ7 with a 304 quadratrac setup. It currently has manual breaks and steering and I want to convert over to power while I have everything torn down. By the way, my ring and pinion gears are trashed so I am open to replacing the entire front axle with one that already has front disc setup if that will swap into a quadratrac setup.
I found this link and others.. http://www.jeepforum.com/forum/f8/da...-help-1254054/
chrbone is offline
post #2 of 4 Old 09-11-2012, 09:40 AM
CSP
The quadratrac Dana 30 is no different than any other Dana 30 of those years (76-79) other than the fact that they have drive slugs instead of lockout hubs. This would have no bearing on a disc conversion.
CSP is offline
post #3 of 4 Old 09-11-2012, 04:23 PM Thread Starter
chrbone
1976 CJ7
Would you suggest finding a Dana 30 front end that is equipped with disc brakes and is working rather than rebuilding the trashed ring and pinion on my current front end and having to upgrade to discs in regards to money?
chrbone is offline
post #4 of 4 Old 09-11-2012, 05:12 PM
CSP
If you can find one with the same gear ratio, sure.
CSP is offline
Dana 30 Disc Brake Conversion Help MarmadukeMSB Jeep CJ Forum 17 03-01-2016 07:25 PM
Another CJ Dana 30 disc brake conversion question (hopefully a new one) Mackskibum Jeep CJ Forum 15 05-14-2012 04:21 PM
Disc brake conversion help mudslinger74 Jeep CJ Forum 4 02-02-2012 09:05 AM
Drum to disc brake conversion for dana 25 Lifesgoodhere Jeep CJ Forum 25 12-29-2010 03:00 PM
dana 30 disc conversion questions LSUtiger Jeep CJ Forum 9 02-28-2008 05:31 PM
