Dana 30 brake rotor - JeepForum.com
post #1 of 5 Old 04-14-2017, 06:46 AM Thread Starter
JohnnyRotten
1978 CJ5
Dana 30 brake rotor
Please be easy on me...I did a search and didn't see anything I also searched the web and saw nothing. Does anyone sell a front brake rotor for a 78 CJ 5? When I look at any of the parts stores all I can find are just the rotor. Mine does not have the hub that these rotors bolt to. Mine is an all in one unit. Where can I find a rotor at? If no rotor available where can I find one of the hub assemblies these rotors bolt to? Thanks.
JohnnyRotten is offline
post #2 of 5 Old 04-14-2017, 08:22 AM
OrangeCJ-5
1978 CJ5
So you do not have the hub or rotor?
OrangeCJ-5 is offline
post #3 of 5 Old 04-14-2017, 08:27 AM
STJP
STJP's Avatar
STJP is online now
post #4 of 5 Old 04-16-2017, 05:24 AM
Rebel442
Forgive me if I'm wrong, as I haven't seen one in some time. But if you knock out the lug nut studs won't the rotor separate from the hub?
It Wouldn't Be A Project If Everything Worked Right.
Rebel442 is offline
post #5 of 5 Old 04-17-2017, 05:22 PM
CSP
Yes yours does have the hub and it's not an all in one unit. The wheelbearing hub is attached to the rotor via the lug studs. Push/press the lug studs out through the back side and the two pieces will separate.
CSP is offline
