Dana 30 Bearing Replacement and...who knows what... - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Dana 30 Bearing Replacement and...who knows what...
DIY tube fender kitsAmsteel Blue Synthetic Winch line Free ShippingRing & Pinion's, Lockers, 4340 Axles, Install Kits, Ba
Unread 10-13-2011, 07:44 PM   #1
ASteve
ASteve's Avatar
1972 CJ5
OK Guys,
I might have a few questions along the way, but here's where I am at so far.
The first step should have been to remove the allen bolts that hold the Warn face plate on, then remove the rest of the Warn Locking Hub.
Anyways, now I am waiting to receive my one specialty item to remove the nut...spindle nut socket.
edit... Disclaimer...this is by no means a how to but rather my step by step learning process...
http://www.astevecali.com
ASteve is offline   Reply With Quote
Unread 10-13-2011, 08:32 PM   #2
WindKnot
WindKnot's Avatar
1977 CJ7
I'm happy to see you ordered the socket. It's what's best for tightening it up for the bearing's sake. Chances are very good that you can loosen it without damaging it with a punch and hammer. (Notice I said LOOSENING it) More than likely it is not on there very tight at all.
The choice is ALWAYS YOURS! it's your Jeep afterall.
No, I do NOT play the bagpipes. My ancestors just killed people!
WindKnot is online now   Reply With Quote
Unread 10-14-2011, 07:12 AM   #3
billybob535
1974 CJ6
Your other post mentions that you are going to replace the ball joints and u-joints. There is a special socket required to tighten the ring on the top ball joint and you should make sure you have a socket big enough to fit the top ball joint nut. I just tore down 3 dana 30s for my build and I had to go buy a socket for the top nut as my set only went to the next size down.
When it comes time to take the spindle off you will want a spindle socket and slide hammer. I thought I could do it without and after the first one I went and got the socket. Autozone loans both of them for free and it will make life easier. Since you are going to have the spindle off to replace everything else you will want to do the spindle bearings too. You can get them out with a pilot bushing puller (another free loaner from AZ if you don't have one). Put the new ones in the freezer overnight and they will shrink slightly making them easier to install.
If you replace the spindle stud nuts, I found the easiest/cheapest place to get them was AdvanceAutoparts. They are 3/8"-24 grade 8 prevaling torque lock nuts (Dorman P/N 247-012 is for the box of 25). Cost was $12.
Good Luck
Bob
74 CJ6 - 304/TF-999/D300/D30/D44 - build in progress
billybob535 is offline   Reply With Quote
Unread 10-14-2011, 01:18 PM   #4
ASteve
ASteve's Avatar
1972 CJ5
Thanks Billy!
Really appreciate the heads up. I have the pilot bushing puller just need to get the slide hammer and I hope this slide hammer works on the rear as well.
Again thanks.
SC
Unread 10-14-2011, 01:50 PM   #5
billybob535
1974 CJ6
I have the Harbor Freight slide hammer kit and it works great. I ripped the last 1/2" of threads off of it pulling a stubborn spindle so I cut that part off, beveled it, and screwed the socket right back on to finish the job. I have used it to pull rear axles too. It came with the parts to use with a rear axle. The spindle socket AZ loaned me was brand new so I kept it instead of returning it to get my $35 deposit back. They cost the same if you bought one retail somewhere and it worked so good I decided to keep it.
Do you have a press to do the ball joints? They loan those too. I got the one from HF a long time ago and use it for ball joints, u-joints, and as a huge c-clamp once in a while. I think AZ also loans the ball joint spanner socket but if not here is a link to buy one.
Unread 10-14-2011, 02:01 PM   #6
MoC
Invisible
MoC's Avatar
This link might help
MoC is offline   Reply With Quote
Unread 10-14-2011, 02:23 PM   #7
ASteve
ASteve's Avatar
1972 CJ5
Billy,
Great info... and MoC I saw your posts on that thread before and bookmarked it...Thanks!
Billy you can get the spindle socket here for $8.99... http://www.quadratec.com/products/98001_00.htm
Laslty, what do you guys use to degrease the parts here?
SC
Unread 10-14-2011, 02:28 PM   #8
MoC
Invisible
MoC's Avatar
Brake cleaner and a wire brush works well. I think the advanced brands cleans better than the auto zone brand. If I have a large amount of stuff to clean I use a 5 gallon bucket with some gas in it. Keep in mind that both of these are bad go get on your hands.
Good luck!
Unread 10-14-2011, 02:31 PM   #9
ASteve
ASteve's Avatar
1972 CJ5
MoC,
I know Brake Cleaner works great but will it harm the plastic parts connected to the Warn Face Plate?
SC
Unread 10-14-2011, 02:36 PM   #10
MoC
Invisible
MoC's Avatar
Not sure, might just fade the color.
Unread 10-14-2011, 02:40 PM   #11
billybob535
1974 CJ6
Originally Posted by ASteve View Post
Billy,
SC
That's the spindle nut socket. The AZ loaner I was referring to is a spindle puller socket. It screws onto the threads on the end of the spindle and then onto the threads of your slide hammer. It allows the easy removal of the spindle (which is a light press fit in the knuckle). AZ won't allow a link to it but here is another one like it.
Unread 10-14-2011, 02:43 PM   #12
billybob535
1974 CJ6
MoC,
SC
Plastic parts? What plastic parts do your lockouts have. Mine were all metal.
I would use gas or brake parts cleaner and a stiff toothbrush. Just wear some rubber gloves (kitchen ones seem to do well for this).
Unread 10-14-2011, 03:42 PM   #13
WindKnot
WindKnot's Avatar
1977 CJ7
I use good ol' solvent. Solvent is expensive thugh. Diesel will work but it is oily. Buy some nitrile gloves. I used to pooh pooh them until I used the first pair. Now I'm cinvinced!
Unread 10-14-2011, 07:45 PM   #14
ASteve
ASteve's Avatar
1972 CJ5
Oh ... got it...
I was going to do like MoC and put my spindle nut back on and use a puller, but I like the tool you linked in.
Unread 10-14-2011, 07:48 PM   #15
ASteve
ASteve's Avatar
1972 CJ5
You're right it's not plastic. It just looked like it when it was covered in grease...which brings me to another question. Jeephammer suggests some sort of synthetic high temp grease. What do you guys use for repacking the bearings and hubs?
Also, if my axels leak oil ... is this from the differential and is that seal easy to replace?
Again, thanks to you all.
SC
