dana 30 4wd stuck - JeepForum.com
post #1 of 5 Old 11-07-2013, 01:17 PM Thread Starter
gRim11x
dana 30 4wd stuck
Hello all I have a 86 CJ with a dana 30 front. It rolls fine in 2wd but when I put it in 4wd high or low it wont budge any ideas? also I have very little experience with axels but I am eager to learn.
gRim11x is offline
post #2 of 5 Old 11-07-2013, 01:38 PM
Spieg8
1984 CJ8
Sounds more like a TC problem than an axle problem... If you lock the front hubs and leave the TC in 2-HI, does the Jeep drive okay? If so, I would check the shifter linkage on the TC. If one of the pins comes out, odd things can happen.
Spieg8 is offline
post #3 of 5 Old 11-07-2013, 01:42 PM
Agent620
Are the differentials the same ratio? I would check that first.
Thanks to Anticanman who gave me a membership!
Chris Hansen is reading this thread.
If you've ever been in that traffic, you would have ground down the steering wheel with a death grip too. "Just ****ing GOOOOOO!!!!"
I pitty anyone who tries to reach into that netting unaware.
'99 TJ (DD)
'89 XJ (WIP)
Agent620 is offline
post #4 of 5 Old 11-07-2013, 03:20 PM
Mr_Ranger
1978 CJ5
Verify that the TC is moving by pulling the front drive shaft and have someone watch the yoke. Move it a few inches. If it turns, drain the fluid from the front axle and remove the differential cover and check the gears.
Mr_Ranger is offline
post #5 of 5 Old 11-07-2013, 03:21 PM
JeepHammer
Running On Empty...
1973 CJ5
Axles the same ratio, like addressed above, and I'd try it with the front hubs UNLOCKED...
If it moves with hubs UNLOCKED, you simply spin the differential and axle shafts, no harm, but that will tell you *IF* the front ring/pinion is locked up or not.
If it still doesn't want to move in 4x4 with the front unlocked, then the issue is with transfer or front pinion/ring gear...
You could also jack up the front, put T-case in 2WD, lock in the wheels and turn them, see if the front ring/pinion turns the drive shaft freely,
Then you would start looking at transfer case...
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
