Dana 30 & 44 Axels - JeepForum.com
post #1 of 16 Old 05-26-2004, 02:29 PM Thread Starter
jeepwillies
Dana 30 & 44 Axels
I am getting ready to purchase a Dana 30 front and 44 rear axel to swap into my 52 CJ. I was told to go with early (1970-1975) CJ Dana 30 and 44's. The dude at the Jeep store says that I need a newer front (30) than I originally thought, because the 1970 to 1975 CJ's had drum breaks on the front, which is part of the reason I am swapping them in the first place. Can anyone set me straight on this? Do I need a newer model? Really I just want two axels that require little modification with an open knuckle design and front disk brakes.
I drive a JEEP.......Therefore I am!
jeepwillies is offline
post #2 of 16 Old 05-26-2004, 03:02 PM
SuperDave
SuperDave's Avatar
Mid year 1976 is when disc brakes started on the CJ's.
86 CJ-7 Stock parts left-Dashboard!
SuperDave is offline
post #3 of 16 Old 05-26-2004, 03:08 PM Thread Starter
jeepwillies
I am of the understanding that only the early years 70-75 are available in the narrow track. Is that correct?
post #4 of 16 Old 05-26-2004, 03:26 PM
80cj
80cj's Avatar
1980 CJ5
You're aware that you'll have to change your transfer case too, right? The axles you want have a centered rear diff.
80cj is offline
post #5 of 16 Old 05-27-2004, 12:14 PM Thread Starter
jeepwillies
Are they available in the narow track?
post #6 of 16 Old 05-27-2004, 12:16 PM Thread Starter
jeepwillies
Nope, i was not aware!!??!! Any clue on which t-case i will need, and or adapters? thanks for your help.
post #7 of 16 Old 05-27-2004, 04:08 PM
80cj
80cj's Avatar
1980 CJ5
Either Dana 20 or 300. The rear output has to be in line with the rear differential pinion gear. Assuming you still have the stock Dana/Spicer 18 stransfer case that come with your model, the rear output shaft is too far off to the passenger's side. More than the U joints will tolerate .
Assuming that you have the stock T-90 transmission, I believe there are Dana 20 cases that will bolt up with out an adapter. I could be wrong on this so any one knowledgeable feel free to correct me. Problem with a Dana 20 is that the low range is only 2:1. A 300 has a 2.6 low range but will not bolt up to a T-90 with out adapters and even then, I am not aware if adapters are available for a T-90 application.
80cj is offline
post #8 of 16 Old 05-27-2004, 04:37 PM
MudMonster
MudMonster's Avatar
i dunno either as far as what will bolt up, bound to be an adapter look at advance adaptor's website or novak's. and as far as front axles go you have 3 options, drum, narrow trac disk, and wide trac disk.
"Don't be too proud of this technological terror you've constructed"
RED JEEP CLUB MEMBER #78
BIG GUNS AND JEEP OWNERS OF AMERICA CLUB MEMBER #3
Red Neck Jeep ClubMember#27Fire Engine Red '85 CJ-7, Howell FI-258, T-176, D300, 9", Warn Internal Hubs, Wagoneer front springs, RE Wrangler's in the rear, 33" TrXus', HEI conversion, Taurus fan, no emissions junk, and some 150w daylighters
MudMonster is offline
post #9 of 16 Old 05-27-2004, 05:22 PM
bwatsonxj
Junior Member
why narrow trac
if your going to match up the widths for originality thats one thing. but the simple up grade to wide trac is another. wider is better.
bwatsonxj is offline
post #10 of 16 Old 05-28-2004, 03:14 AM
meich75
meich75's Avatar
I could be wrong but I think the narrow trac was available until 83.
meich75 is offline
post #11 of 16 Old 05-28-2004, 04:03 AM
rapha
i don't it goes so far, i thought it was till 1975.
my cj 6 from 75 , comes stock with a front d30 , rear 44 , 20 tc.
but has front drum brakes ,
i need to upgrade to disk ... but i don't want to by this expensive kit,
91 laredo XJ , 4 inchs lift , rancho ,rear hitch , dyno-max ,
butan converted 4.0 HO
new project 75 CJ6 v8
rapha is offline
post #12 of 16 Old 05-28-2004, 07:43 AM Thread Starter
jeepwillies
Here is what i am going to do. Get a pair of narrow tracks D44 and D30 with drums and perform the following.
http://www.4x4wire.com/jeep/projects/pieces/front/
post #13 of 16 Old 05-28-2004, 09:31 AM
rustyCJ
dana 30s from 76 - 81 were narrow track with disc brakes.
if i am not mistaken 70 - 72 cj dana 44s were offset for the dana 18 and used the flanged shafts.
these are the axles i would be looking for if doing this swap.
another option for a rear would be an offset amc20 from a QT'd cj.
just some food for thought
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #14 of 16 Old 05-29-2004, 05:52 PM
80cj
80cj's Avatar
1980 CJ5
I believe the offset flanged 44 was available only on 71 CJ-5's. A rare one indeed. If you use the QT AMC 20 be sure to installed one piece axles.
80cj is offline
post #15 of 16 Old 05-29-2004, 10:08 PM
plain76cj5
All CJ5's had narrow track axles, until the end of production in 1983. 1976 to 1981 CJ7's had narrow axles. 1982-up CJ7 & 8 had wide track axles. 1971 models use D44 axle with Dana/Spicer 18 transfer case. 1972 used D44 with Dana/Spicer 20, which would be a centered differential.
plain76cj5 is offline
replacing stock axels with one piece axels coondognc Jeep CJ Forum 5 04-22-2009 01:22 PM
axels nichols077 Jeep CJ Forum 2 10-21-2006 02:38 PM
toyota axels strong as dana 60? humboldt_jeep Jeep CJ Forum 3 05-07-2004 07:39 PM
Scout Dana 44 Axels jeepwillies Jeep CJ Forum 1 02-23-2004 12:32 PM
Axels jeepwillies Jeep CJ Forum 1 12-30-2003 10:02 PM
