dana 27 - JeepForum.com
post #1 of 4 Old 01-12-2010, 01:47 PM Thread Starter
CooterBrown
CooterBrown's Avatar
1965 CJ5
dana 27
is the cover for a dana 27 and a dana 30 the same size,. im not so much interested in putting a new cover on it as i am with getting a fitted gasket. im sick of cork gaskets splitting in a week. and leaking. if not any one know where i can find a good dana 27 gasket. i really like the lube locker gaskets even though they run a little high.
CooterBrown is offline
post #2 of 4 Old 01-12-2010, 06:20 PM
Nickmil
Dana 25, 27, and 30 use the same gaskets. The 25 has the vent in the cover and most 27's and 30's have the vent in the housing. Other than that they interchange.
'59 CJ-5, '59 CJ-6, '68 CJ-5, Bone stock '57 CJ-5, a couple of XJ Cherokees
Nickmil is offline
post #3 of 4 Old 01-12-2010, 09:50 PM Thread Starter
CooterBrown
1965 CJ5
AWSM thanks. did the shape of the 30 ever change why does quadratec offer a dana 30 cover for early yr models and a 30 for later models does that make any diference
post #4 of 4 Old 01-13-2010, 07:58 AM
Nickmil
Because some early YJ's were a high pinion differential so the fill plug had to be higher to raise the oil level for proper lubrication. The others are low pinion so the fill plug is lower. Shape and gasket are the same.
Nickmil is offline
1985 CJ8 swapping in Dodge 1 ton Dana 44 front and Dana 60 rear?????????? JeepScrambler Jeep CJ Forum 8 05-21-2012 06:30 PM
Switch from T176 and Dana 300 to T150 and Dana 20?? Need Advice CJ5Freak Jeep CJ Forum 11 07-26-2008 06:56 AM
Swapping Disc Brakes from 81 Dana 30 to 76 Dana 30 PortlandCJ76 Jeep CJ Forum 2 05-13-2007 04:11 PM
dana 44 spindles bolt to dana 30 nuckles? CJ7Laredo Jeep CJ Forum 2 09-26-2006 10:55 PM
Scout dana 20 vs jeep dana 20 (internal gears) pityocamptes Jeep CJ Forum 3 05-18-2004 11:19 PM
