Dana 20 transfer case. Hard to find 2WH - JeepForum.com
post #1 of 3 Old 03-31-2004, 10:36 AM Thread Starter
T Hoff
1975 CJ5
I've had my '75 CJ5 since 1979. I've always had this problem so I was wondering. When I shift from 4WD up thru neutral and into 2WD I never feel any indication that it's in. I'm guessing there should be some ball spring that clicks into a notch in the shaft.
Is this game of hit or miss typical for the DANA's?
Is there something I can look for externally that might indicate I'm missing something, like a long hole that should have a spring and steel ball in it?
It's not that much fun to get back on the road, Shift out of 4WD and as you accelerate, have the T-case pop into Neutral. Can't be good for the gears either.
'75 CJ5 ---Chevy HP 350 motor-- All Fiberglas---one piece tilt forward nose
1985 chevy stepside pickup, 300K on the clock: Original Owner
1989 Volvo 240 300K on the clock: Original Owner
the 1991 X is my newbie with 331K on the clock: bought OCT.'03 with 183K
T Hoff is offline
post #2 of 3 Old 03-31-2004, 10:42 AM
fuzz401
1978 CJ7
it should not be that hard mine never was there is a spring and dentant ball in the shifter housing that could be hanging up but would have to pull the case to look at it
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline
post #3 of 3 Old 03-31-2004, 10:45 AM Thread Starter
T Hoff
1975 CJ5
no way to see it by taking off the Boot and looking by the shifter? I guess not, The Case is pretty far behind the shifter.
OK though..it is a detent ball and spring setup. I thought it might be.
Thanks
T Hoff is offline
Dana 300 Transfer Case kuhndogs Jeep CJ Forum 3 01-19-2009 05:59 PM
dana 20 transfer case. Tell me what you know sail78385 Jeep CJ Forum 4 07-19-2008 08:47 PM
Dana 20 Transfer case Scott 77CJ Jeep CJ Forum 5 08-03-2007 10:51 AM
Dana 300 transfer case calcallender Jeep CJ Forum 7 12-02-2005 04:30 PM
