Dana 20 top speed - JeepForum.com
post #1 of 10 Old 01-07-2012, 11:19 PM Thread Starter
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
Dana 20 top speed
A buddy from H.S. is moving to Cali. He'll be running in sand dunes and beaches alot and we both had the same same set up back then. He still has the 304/T-150/AMC 20 T-case and AMC 20 rears w/3.73gears. We usually ran 33x12.50s. Although we never got to find out back here in the Pa woods, but what is the top end of this steup in 4-high? We never went much more than 35-50 mph in cold snow. No we're curious as to how fast he can rip across a semi low traction area for miles w/o burning something up in hot weather. He does have the dbl Cardan driveshaft in the rear, which he did when he did a total mechanical re-hab in 2006 (3,500 miles ago!). Not the most important question to come up, but he's afraid that 60 mph for 15 mins will seize the t-case in 4-hi...or something. I told him I knew some smart people who would know these things! Thanx guy/gals.
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #2 of 10 Old 01-07-2012, 11:26 PM
Skerr
As long as everything in the drivetrain is in good condition, and the fluids are current and properly filled, I would say the limiting factor would be the topend of his Jeep's capability. I think the T-150 would be the weakest point of the whole thing. I don't think the AMC20 will cause any problems in sand with 33s.
To edit: It also has something to do with Murphy's Law. It is directly proportionate to how many guys are chasing him, and how badly he needs to get away!!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #3 of 10 Old 01-07-2012, 11:40 PM Thread Starter
hutch1200
hutch1200's Avatar
1979 CJ7
Semi Divorees
Yeah, that semi/sorta divorced woman will really test a vehicle and yer skills!
post #4 of 10 Old 01-08-2012, 12:22 AM
nshefbuch
1982 CJ7
FYI. It's not a amc 20 tcase but a Dana 20.
Never mind, I see you have it right in the title but not the OP. sorry
CJ7/SOA YJ leaf/5.3LS/t18a/d300 clock/37"Pitbull Rockers/H1's/14 bolt/d44 ARB 4.10 High Steer
nshefbuch is offline
post #5 of 10 Old 01-08-2012, 12:48 AM
lucdog
1980 CJ5
After a little google searching, 55 seem to be the norm for a number of different vehicles, altho these are mostly chain drive TC's, and the owners opinion. Its also not comparing apples to apples.
Probabley the most interesting thing I read was, "if your going 60 why do you even need 4wd" . this came from 2 different people in 2 different forums.
I should be interesting in the morning with the replys.
On edit, after 8 google pages, I couldn't find anything. This was probabley the best one. http://classicbroncos.com/forums/sho...d.php?t=105367
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #6 of 10 Old 01-08-2012, 02:54 AM Thread Starter
hutch1200
hutch1200's Avatar
1979 CJ7
Thanx lucdog. I remember my dad, like people listen to them, saying 55 mph was top speed for any slippage on a t-case..... even q-trac.
post #7 of 10 Old 01-08-2012, 07:29 AM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
In sand and other "loose" mediums, you can drive as fast as the vehicle will go without issues (provided the entire drive train is solid and well maintained). Guys running these systems have raced SCORE, and Baja for years with out any issues. Generally, I would be more concerned with an automatic transmission getting hot, but even that can be controlled with an aftermarket fluid cooler mounted on the radiator.
jeepdaddy2000 is offline
post #8 of 10 Old 01-08-2012, 01:08 PM Thread Starter
hutch1200
hutch1200's Avatar
1979 CJ7
Thanx guys. My bud is at ease now. He had visions of tearing along and having /chains/gears ripping through the floorboards at him! But does anybody ever listen to me....well maybe he does have a few reasons.
post #9 of 10 Old 01-08-2012, 01:43 PM
AFRd_CJ5
1976 CJ5
Though not sustained, we've ran a 20 in dads Jeep for a number of years. Mid 70'sMPH for multiple passes at the dunes. Round and round it would go. In 4H, the 20 seems to be able to handle some abuse. From years on the dunes, my experience has been that you can only go as fast as your suspension allows. If the dunes you're at aren't completely flat all over, your limiting factor for speed will be your suspension.
'76 CJ5
434 pump gas SBC with an NX/HVH plate system
th350/Coan 5,000 converter/Dana 300 tcase
Dana 30 front with 4.56's/Dana 44 rear with 4.88's
AFRd_CJ5 is offline
post #10 of 10 Old 01-08-2012, 04:19 PM Thread Starter
hutch1200
hutch1200's Avatar
1979 CJ7
He still has the Rancho 3" springs we both bought senior year w/new shocks in '06. He thinks he'll be trying to catch up w/Bo Derek on the beach. I just hope he's smart enough to keep it out of the salt! I forgot you ran that setip in your digger, thanx.
What's needed? T-5 5 speed to T-150 3 speed cjsabo Jeep CJ Forum 2 02-09-2010 07:56 AM
Can a 63' 3 speed be converted to a 4 speed jgrassw Jeep CJ Forum 5 08-17-2009 07:54 PM
witch gasket do you use when mating the dana 20 to a t150 3 speed yojeep79 Jeep CJ Forum 6 07-27-2009 09:55 AM
Shifter Level for Dana 300 w/3-speed auto mjr03c Jeep CJ Forum 4 04-14-2009 08:45 PM
85 cj7 3 speed or 4 speed auto? tbury85cj7 Jeep CJ Forum 6 03-10-2009 10:35 PM
