Quantcast Dana 20 from T18 or T150. Any difference? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Dana 20 from T18 or T150. Any difference?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 11-19-2006, 10:12 PM   #1
hfjeff
1978 CJ7
I am searching a replacement Dana 20 for my T150 (sore subject so I won't go into details but these Dana 20's are tough!). I have come across several and need to know if there is any difference between a Dana 20 that was mated to a T18 and a Dana 20 that was mated to a T150. I am sure the bolt pattern is the same but what about the input gear? Are they also the same? Are the transfer cases interchangeable without mods? Or should I stick with Dana 20 from T150 to avoid any compatibility issues?
MINE: 1978 CJ7/ AMC 360 .030" over/ Motorcraft 2100/ Edelbrock Performer/ Proform HEI Ignition/ Hedman Headers with dual Flowmaster 40's/ Taurus Fan/ FK-35 Control/ Painless Harness/ Rebuilt T150 & Dana 20/ 4" Lift/ 31" Procomp Mud Terrains/ All Fiberglass.
MY SONS: 1996 ZJ Limited/5.2L/117K & Completely Stock
hfjeff is offline   Reply With Quote
Old 11-19-2006, 11:24 PM   #2
redneck23ms
they are identical. shift linkages may differ a bit but thats all.
redneck23ms is offline   Reply With Quote
Old 11-20-2006, 07:44 AM   #3
hfjeff
1978 CJ7
So the output gear of a Jeep T18 is the same as the output gear of a T150?
Old 11-20-2006, 10:10 AM   #4
CJ51973
CJ51973's Avatar
Yes it's the same
Anything is possible if you don't know what you are talking about.
CJ51973 is offline   Reply With Quote
Old 11-20-2006, 10:28 AM   #5
jason m
like everone else is sayng they are the same expect for the shift linkage tube is longer for the T-18, this is so bolth T-case shifter and transmission shifter will drop thru the same holes in the floor, jason.
jason m is offline   Reply With Quote
Old 11-20-2006, 10:45 AM   #6
hfjeff
1978 CJ7
Cool, that opens up my options a bit. I have seen some with the U pattern shift. Anyone using that as opposed to the straight front to back in their CJ? More than likely the floor shift cover would have to be cut? Would there be any advantage? The reason I am asking is I have about 1" body lift so the clearance is very tight to get it into 4H. I think it would probably pop out of 4H on a bumpy trail due to body flex and the shifter cover hitting the shifter.
Old 11-20-2006, 01:19 PM   #7
CJ51973
CJ51973's Avatar
The "U" pattern is from a J truck. The shift rods are different than the lever CJ type. If you end up with one I have a U shifter. It worked pretty slick but no 2WD low
Old 11-20-2006, 01:25 PM   #8
plain76cj5
Some of the Dana 20's from fullsize Waggys, Cherokees, and J Trucks will have a flange type yoke for attaching the driveshafts. You can swap the "U bolt" type yokes easy enough.
Jeep #1 = 76 CJ5, 304, T18, Twinstick Dana 20, Lock-Right in front, Yukon HD front axles, One piece axles - Detroit Locker in rear, 2.5" Rancho Springs, 1" lift shackles, 32x11.5 Super Swamper TSL/SX, Warn XD9000i, York OBA.
Jeep #2 = 80 CJ7, 401, T18, D300, 3" Black Diamond Lift, TrXus M/T 33x12.5, Yukon 1 piece axles, Auburn posi in rear, Detroit TrueTrac in front, Ramsey 8000.
plain76cj5 is offline   Reply With Quote
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
