DANA 20 shift pattern - JeepForum.com
post #1 of 5 Old 07-21-2009, 05:53 PM Thread Starter
carguy68ssrs
1977 CJ5
New to Jeep thing, want to know if Dana has 5 shift locations. Have a 77 CJ5 with 258 and 3 spd. PO installed billiard balls for shift knobs so no pattern. Seems to have 4hi 2hi N 2lo 4lo by watching front shaft turn. Online parts places don't show this pattern for replacement knobs in pics. Any help would be appreciated.
carguy68ssrs is offline
post #2 of 5 Old 07-21-2009, 05:57 PM
Lockport XJ
1979 CJ7
Should be in the following order from front of vehicle to back:
4hi
2hi
N
4low
1979 Renegade, AMC 360, PS Crusher Corners, PS Rock Sliders, 4" Procomp Lift, 33x12.5 Remington Mud Brutes, DC10 15x10 Wheels.
Lockport XJ is offline
post #3 of 5 Old 07-21-2009, 06:08 PM Thread Starter
carguy68ssrs
1977 CJ5
Thanks, found in an old thread that 2lo comes from t case being worn and not going into 4lo all the way
post #4 of 5 Old 07-21-2009, 07:49 PM
ccbhunter14
yep, mine goes into 2lo, which i found pretty confusing at first as i didn't know this was possible, it's not the most useful thing, but i think it's kinda cool
If it's not leakin', it's probably empty '84/'77 CJ7 Ford 302 4bbl Holley
Just Enough Essential Parts
I drive like everyone's out to get me...because they are!
ccbhunter14 is offline
post #5 of 5 Old 07-22-2009, 08:55 AM
CSP
2lo is a result of the linkage getting worn, not the transfer case. Slop develops in the linkage allowing the shift rod for the rear output to go into low range while the shift rod for the front output is still in neutral.
With fresh linkage parts both shift rods engage low at the same time. You can actually shim the slop out of the linkage by adding AN washers and each connecting point, but having 2lo can be useful.
CSP is offline
DANA 20 with odd shift pattern STORK1313 Jeep CJ Forum 3 11-05-2009 10:49 PM
Shift pattern for a dana/Spicer 20 t-case BrockGrimes Jeep CJ Forum 4 12-27-2008 08:09 AM
Dana 20 twin stick shift pattern GPER Jeep CJ Forum 1 03-22-2006 06:31 PM
Shift pattern for D20 awachwhiteboy Jeep CJ Forum 7 03-17-2004 10:32 AM
Dana 20 trans. case shift pattern thecro Jeep CJ Forum 2 04-04-2002 10:35 AM
