Dana 20 intermediate shaft kits - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Dana 20 intermediate shaft kits
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 12-21-2015, 10:27 AM   #1
Stumpfarming
1974 CJ5
I am about to order a new intermediate shaft kit for my Dana 20. I've noticed that the kit from Novak is more than double the cost of the Crown or Omix-Ada kit. Is the Novak kit that much better, or just overpriced? Does anyone have any feedback regarding the "lesser" kits?
http://www.jeepforum.com/forum/f22/stumpfarmings-73-cj5-build-1935041/
Stumpfarming is offline   Reply With Quote Quick reply to this message
Unread 12-21-2015, 10:47 AM   #2
chromegrille
1947 CJ2A
You get in quality what you pay for....as far as intermediate shafts go.
Novak much better, harder shaft.
Forget the offshore junk unless you want to do the job over again in 6 months (or less).
chromegrille is offline   Reply With Quote Quick reply to this message
Unread 12-21-2015, 02:37 PM   #3
HackFabrication
1976 CJ5
On a side note....
The intermediate shaft only goes into the case one direction. Don't try to put it in the wrong way!
"In the end...It's all Hack."
HackFabrication is online now   Reply With Quote Quick reply to this message
Unread 12-21-2015, 06:15 PM   #4
Partsmke
Novak advertises "triple alloy". Here is the definition for 8620 Steel. This chromium-molybdenum-nickel "triple alloy" is a widely used case hardening alloy grade. Used where high surface hardenability and tough core is desired along with easy machinability and excellent wear resistance. The chromium and molybdenum contribute to hardness penetration while the nickel increases the toughness. Typical applications include: gauges, jigs, gears, piston rods, plastic molds, cams, pinions, spline shafts.
Partsmke is offline   Reply With Quote Quick reply to this message
Unread 12-21-2015, 06:16 PM   #5
82JeepCJ7
1982 CJ7
I built a "Tool" on a lathe to hold the needle bearings inside the intermediate gear while the shaft was being inserted.... Saved a ton of frustration....
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline   Reply With Quote Quick reply to this message
Unread 12-21-2015, 07:06 PM   #6
Stumpfarming
1974 CJ5
Thanks everyone for comments. It sounds like an extra $50 now will save me more than $50 in headaches later. :-) Yes, I am aware of the tapered shaft and even caught myself wanting to drive it the wrong way during disassembly. An easy mistake to make as I discovered. If I had access to a lathe, a "tool" would be a great idea. I'll give it a go with assembly Lube or Vaseline to hold Them in place when putting together, but I am guessing that tapping the pin in will likely dislodge a few of the bearings.
Unread 12-22-2015, 06:34 AM   #7
jeepdaddy2000
1971 CJ5
Grease works just fine.
again, insure you replace the thrust washers as well.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 12-22-2015, 10:23 AM   #8
Stumpfarming
1974 CJ5
Originally Posted by jeepdaddy2000
Grease works just fine. again, insure you replace the thrust washers as well.
Will do! The thrust washers almost look worn worse than the center shaft.
Unread 12-22-2015, 06:19 PM   #9
82JeepCJ7
1982 CJ7
A short wood dowel works too.
Unread 12-23-2015, 08:41 AM   #10
HackFabrication
1976 CJ5
That's the 'trick' I used when I rebuilt and added the TeraLow kit to mine:
Unread 12-23-2015, 05:24 PM   #11
BeatCJ
1981 CJ5
Don't use grease. Use Vaseline, or assembly goo. Grease doesn't melt out at transfer case temperatures.
There are some things you will learn while holding a cat by the tail that can be learned no other way...
BeatCJ is offline   Reply With Quote Quick reply to this message
Unread 12-23-2015, 06:43 PM   #12
Stumpfarming
1974 CJ5
Yep. I've heard that from several sources and plan on following that advice. Thanks! :-)
Unread 12-23-2015, 06:56 PM   #13
BeatCJ
1981 CJ5
I have rebuilt a couple of Dana 300s using Novak Kits. It wasn't a bad job, they have excellent instructions. I don't know how much difference there is between the 20 and 300. I didn't need a holder/spacer for the intermediate gear needles, just Vaseline, it seemed like they almost snapped into place when I got the last one in.
Unread 12-23-2015, 09:23 PM   #14
jeepdaddy2000
1971 CJ5
However did those hundreds of transfercases and transmissions I've rebuilt over the years ever survive.
Unread 12-23-2015, 10:41 PM   #15
82JeepCJ7
1982 CJ7
I should machine a bunch of them "tools" and make them available...
