11-14-2006, 11:42 AM
#1
Ok so I have 4.10's in my '85 CJ7. I have two rear axles in my possession that I can use for it. A Dana 44 from an '86. It has the 3.31's, a Warn full float kit with upgraded axles and Warn hubs. The AMC20 has also been upgraded to a full float Warn kit without hubs, a detroit and 4.10's. I'm leaning toward the AMC20 due to the locker and 4.10's but it's hard to pass up a good D44 with full float. Any opinions?
11-14-2006, 11:50 AM
#2
truss the 20
Build a truss for the 20, and you will take care of the weakness of the AMC20. If you build it right it will be stronger than the 44
YeloCJ, 360, 36's and Detroits f/r, T-18, Tera-low 20
11-14-2006, 01:58 PM
#3
Chief of the brain police
I would go with the amc 20 and build a truss also, the 20 has a bigger ring gear and with the one piece shafts is a good axle
11-14-2006, 05:48 PM
#4
I might be interested in which ever you don't use
85 CJ-7 Laredo 258 I-6, Hardtop
1" Shackle Lift
1" Body Lift
Sway Bar Discos
Aluminum Valve Cover
33x9.50 BFG M/T
Warn 9000xdi
New parts waiting for me to install:
narrowed Waggy Dana 44 frontend
Warn hubs, spindles, and outer axles
MORE shackle reversal and steering box bracket
4" springs
11-14-2006, 07:09 PM
#5
I am in the same situation. I have run the AMC20 built with a detroit and 1 piece axles and never had an issue. Ialso picked up a parts rig with a Dana 44. I am SOA, so I didn't feel like welding new perches or changing over to the buying a new locker and gears for the Dana 44. I have abused my AMC 20 and it has held, so I would go with the 20 over the 44. My 2 cents...
85' CJ7 Laredo, 383 GM, Turbo 350, NP 203. SOA, 2" frame lift, 34" TSL swampers, Dana 30 open, AMC 20 w/ detroit locker, 4:10's, 1 Piece Mosers, 35" boggers to abuse when needed.
11-14-2006, 08:43 PM
#6
Correct me if I read this wrong, but the AMC 20 he is talking about has the full float (not the 1 piece) axles. AND the 20 has a detroit locker the 44 is open. This makes it a no-brainer...keep the 20, sell the 44, buy a truss, and never look back.
11-15-2006, 03:53 AM
#7
trusses are bad
Tear the 20 apart and have it retubed. Sell the 44 to bank roll it. I did this with my amc20 and it's solid.
Its got a locker, warn full float and is now bombproof without the weak stock tubes. The new ones are about 3/8" wall thickness...BOMBPROOF.
If I bend those, I've got bigger problems than bent axle tubes.
jeepmor
11-15-2006, 07:21 AM
#8
Pro 20
Sounds like we have a Pro AMC 20 group here.
11-15-2006, 08:03 AM
#9
Yeah guess I'll be selling the D44 soon. Thanks dudes.
11-15-2006, 10:18 AM
#10
Anyone got any pictures of trusses they have built for their 20's? Cant you also stitch weld the tubes to the housing for the same result?
79 CJ5 304/T18/Dana 20/30/20(alloy's + locked)
11-15-2006, 10:28 AM
#11
I think you want to ALSO stitch weld the tubes to the housing.
11-15-2006, 10:50 AM
#12
Yes you want to weld the tubes to the housing so they wont roll on you. I havent done it yet, but will very soon. I have a friend who had his turn on him. Messed things up pretty good $$$
1985 cj 7. 360 V8, 35X12.50 BFG's sitting on Crager 15X8 rims, summer brothers axle rear, Yukon axles up front, lock rite lockers front and rear, 5" of lift, body armor, six point roll cage, 8000lb warn winch, 4.56 yukon gears front and rear, t-18, dana 300. And much more on the way.
www.therockgods.com
www.reno4x4.com
11-16-2011, 02:03 PM
#13
Love that all you guys are pro 20, What size tire were you planning on running and what were you planning on doing with the jeep?? Im in the same situation right now, have a chance two buy bolt very cheap and the 20 is welded but the 44 needs work to run it open
11-16-2011, 02:13 PM
#14
Semi (in)competent
Pro 20 5 years ago.
I do hope the OP isn't still trying to decide what axle to get.
My slow efforts at rebuilding and restoring my 1987 Wrangler:
http://www.jeepforum.com/forum/f22/neverending-project-rebuilding-1987-wrangler-1454489/
11-16-2011, 02:36 PM
#15
haha yeah just looked at the date, feel kinda dumb, it was just kinda cool to see all the guys liking them
