D44 making strange noises - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > D44 making strange noises
Halloween Savings to die for!ZONE 4.25" combo lift for TJ available at Rockridge4wNEW!! HMF 50"-52" light bar mounting brackets!!
Unread 10-08-2014, 05:16 PM   #1
dg6772
My 73 D44 with factory limited slip is making some very loud almost rubbing like sounds. I also feel a vibration in the floor while this is happening. There seems to be no real pattern to it,except when I stop,its gone until it starts again. Whenever......
Diff oil looks ok and is full.
Any ideas???
Dave in Muskegon using Jeep Forum App
dg6772 is online now   Reply With Quote Quick reply to this message
Unread 10-08-2014, 09:42 PM   #2
OlympicMountain
1972 CJ5
I'd pull your differential cover and inspect your Trac Lok clutch retainer clips. One of the clips on my 72' came off and started allowing the clutch discs to rotate. One common thing with the clutch discs in those old Trac Lok's, when they start getting old and worn, they get loose enough to let the clips start to move around and eventually come off. They can really start tearing things up if one of the pieces get caught up in a gear.
If it's not a clip, at least by taking the cover off, you'll be able to do an inspection. The clutch kits are under $100.00, and are pretty easy to install. I'd have a qualified shop do it though. It does require a few special tool's and only should take a shop about 1/2 hour shop time if you bring them the differential.
In the picture you can see the distorted retainer clip.
OlympicMountainGeeps
OlympicMountain is offline   Reply With Quote Quick reply to this message
Unread 10-08-2014, 10:57 PM   #3
dg6772
Thanks,I was thinking it was something in that area,but while I've been in many other things,I'm a bit lacking here. I'll check that out tomorrow....
Unread 10-09-2014, 01:18 AM   #4
jeepdaddy2000
1971 CJ5
Make sure your using a friction modified lubricant. Straight 80/90 can cause clutches to chatter.
jeepdaddy2000 is offline   Reply With Quote Quick reply to this message
Unread 10-09-2014, 01:29 AM   #5
dg6772
I did add the additive when I put oil in 2 years ago...
Unread 10-12-2014, 06:53 PM   #6
dg6772
I did some investigating,in doing so,I found the left rear caliper is hanging up. Now,I'm starting to think my problem is a brake issue not the clutch issue I thought it was going to be. I hope it's not both......
Unread 10-13-2014, 09:35 AM   #7
dg6772
Update:
Not brakes either.......turns out, its a bad wheel bearing. Oh well, better than differential!
