d44 axles odd design - JeepForum.com
post #1 of 21 Old 07-24-2009, 06:25 AM Thread Starter
bowtieheep
1983 CJ7
the end of the axles on my rear 44 in my cj has open holes right into the brake drums
they're cast into the shafts where it sticks thru the middle of the drum, you can see the brake's workings thru the hole... not sure why it's like that, not sure if that's normal but it's factory design not jimmyrigging
is there supposed to be some sort of plug in those holes? i don't like havin things gettin in there
bowtieheep is offline
post #2 of 21 Old 07-24-2009, 07:07 AM
DT5150
1983 CJ7
got a pic of it?
SOLD! 83 CJ-7. TBI Small Block Chevy 350/TH350/D300, Scout II Dana 44 front, CJ Dana 44 rear. 4" BDS Lift with 35's. Currently Jeepless.
DT5150 is offline
post #3 of 21 Old 07-24-2009, 07:13 AM
amcjeepman
amcjeepman's Avatar
The hole is to access the bolts that hold the bearing retainer and backing plate to the axle housing.
James Belcher, Jr
Carolina Trailblazers PR
86 CJ7 401 TF999
81 CJ7 360 T177
05 Rubicon Unlimited
and others ;)
amcjeepman is offline
post #4 of 21 Old 07-24-2009, 07:19 AM
mjfitz99
If memory serves the place that I could see into my brake drums
was through the adjusting hole. I remember this becuase I couldn't get the drum off and that was only place to peer into the drum.
mjfitz99 is offline
post #5 of 21 Old 07-24-2009, 08:05 AM
No_Bs
1977 CJ5
This is why. There are supposed to be plugs in them but usually once they are taken out they don't get put back in. When you have to remove an axleshaft, you'll be happy that hole is there.
1977 Cj5, 258, T-18, 2.46:1 Dana 20, 2.5" BDS lift, OBA, 38.5's. Chevy 60 frt, 14b Rear, Full hydro, 102"wb, full DOM cage.
No_Bs is offline
post #6 of 21 Old 07-24-2009, 08:19 AM
foggybottombob
This thread is an amalgam of confusion. There is one fairly large hole in the axle flange so you can stick a socket through it and unbolt the axle retainer nuts (like someone said). This hole is never plugged and there is no reason to do so. When you put the drum on you can't see any of this.
There are holes in the backing plate to access the brake adjuster wheel. These have oblong rubber plugs in them which sometimes fall out. You can get replacements at any auto parts store if you are missing one.
foggybottombob is offline
post #7 of 21 Old 07-24-2009, 10:24 AM
No_Bs
1977 CJ5
This is not always true. I know for a fact that if you use AMC 20 drums on an narrow trac 44, the hole is visible.
No_Bs is offline
post #8 of 21 Old 07-24-2009, 12:17 PM
CJ51973
CJ51973's Avatar
I think he is talking about the 1/2 moon machined in the face of the axle flange where the drum slides on. My 73 Dana 44 had this. It would be a place you could pry the drum off the axle but I wouldn't do that. If you can't get the drum off you need to crank the adjusters in until you can. Anyway, I always thought it was there to prevent the drum from completely rusting.stick to the axle.
Anything is possible if you don't know what you are talking about.
CJ51973 is offline
post #9 of 21 Old 07-24-2009, 12:43 PM
chromegrille
1947 CJ2A
lol.....
the original plugs were metal
they were on every flanged 44 ever made, for Jeep that is.
better study up on the subject first....
chromegrille is offline
post #10 of 21 Old 07-24-2009, 01:46 PM
80cj
80cj's Avatar
1980 CJ5
I had a Dana 44 out of a 74 Jeep Commando and it had plastic plugs in the flange holes but I can see where they could come out easily and get lost. I guess the purpose of the plugs is to keep crud from getting in the brakes.
Edit: I still have the shafts from that rearend and I can see that even with the brake drums installed, a portion of the hole is exposed. Kinda like my AMC 20 with 1 piece axles.
80cj is offline
post #11 of 21 Old 07-24-2009, 03:39 PM
JeepHammer
Running On Empty...
1973 CJ5
YES, There IS supposed to be plugs in those holes.
They look just like thin 'Freeze' (Core) plugs.
They are about 1-3/16", but you will probably have to get a 1-1/8" plug and spread it out with a socket or something before you install.
Someone that can navigate the Jeep Parts Web Sites can probably turn them up at one place or another and post up the link...
Some guys we have here are REALLY good at finding that strange little stuff like that!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #12 of 21 Old 07-27-2009, 06:41 PM Thread Starter
bowtieheep
1983 CJ7
would be cool if someone found that... i'd much prefer to not get crap in there if i could help it
tried 2 parts shops, one was closed, first 2 didnt kno what the hell i meant
i'll drive to one soon as my wheel bearings are put in and my insurance renewed... btw thanks for the front wheel bearing write-up jeephammer, using it for my job, fantastic info!
plus mine's an '83 that originally came with a 4 cyl, now has a 350... i'm aware of no '83 4 cyl that had a dana 44, which mine does
its about 55" wide wms-wms, would that be an original cj axle out of a different one?
post #13 of 21 Old 07-27-2009, 07:03 PM
rokcrawler3203
1974 DJ
You guys are making me confused.
Where is it?
"The road to success is dotted with many tempting parking spaces."
"Of course I keep my dishwater clean, it just looks like chocolate milk and lettuce when I'm done" --Chance; A fellow employee
NITECREW #245
rokcrawler3203 is offline
post #14 of 21 Old 07-27-2009, 07:07 PM
rokcrawler3203
1974 DJ
EDIT:
NITECREW #245
post #15 of 21 Old 07-27-2009, 08:28 PM
80cj
80cj's Avatar
1980 CJ5
Here's my CJ-5 with AMC 20 and 1 piece axles. I guess it wouldn't hurt to find a plug to fit that hole.
80cj is offline
If you had to design a custom dash... NewdRiver_ Jeep CJ Forum 55 08-24-2013 12:33 PM
Hard Top Hoist Design? dreski1 Jeep CJ Forum 9 07-22-2009 12:55 PM
Winch Plate Design NWA_CJ7 Jeep CJ Forum 0 06-12-2009 07:45 AM
258 Engine Design Change crawdad Jeep CJ Forum 6 05-22-2008 09:14 AM
custom design perforance dgsmith50 Jeep CJ Forum 7 06-01-2007 05:53 PM
