D300 4WD switch connector - JeepForum.com
post #1 of 33 Old 03-08-2010, 07:40 AM Thread Starter
VACJ7
VACJ7's Avatar
OK, this has been driving me nuts for some time now. I cannot find the correct size electrical connector that attaches to the 4WD switch on the D300. Its just a small post connection. I have tried various push-on wire connectors that are either too big or too small. The post is not threaded so I can't use a nut. Any ideas?
VACJ7 is offline
post #2 of 33 Old 03-08-2010, 08:28 AM
JKM3134
1983 CJ7
try napa, its a push on pigtail connector
Store Locator | NAPA Online
im not 100% sure that will fit, but it may be worth a shot
JKM3134 is offline
post #3 of 33 Old 03-08-2010, 08:56 AM Thread Starter
VACJ7
VACJ7's Avatar
Yeah, I've tried several different versions of that pigtail with no luck. That little post is just an odd size.
VACJ7 is offline
post #4 of 33 Old 03-08-2010, 09:15 AM
1986cj
I think on my 86, the switch has a plastic washer? around the base of it and the connector goes over the post and snaps on to the plastic washer. This decribes it better. http://www.quadratec.com/products/im...%2F5021-lg.jpg
1986cj is offline
post #5 of 33 Old 03-08-2010, 09:18 AM
LSUtiger
1980 CJ5
I got the harness from collins bros. It was the 4wd light and reverse light harness. Cost less than $25.
edit: It looks like it is $40 now. http://collinsbros.stores.yahoo.net/treliinliwih.html
edit: can't get the link to work. Go to collinsbrosjeep.com
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #6 of 33 Old 03-08-2010, 09:44 AM Thread Starter
VACJ7
VACJ7's Avatar
edit: It looks like it is $40 now. T-176 Reverse Light/4WD Indicator Light Wiring Harness
Yep.... that's the connector! Ughhhh, not willing to drop 40.00 to hack off that connector though. I have an auto so I don't need the rest of that harness. Rats.
VACJ7 is offline
post #7 of 33 Old 06-17-2011, 05:48 PM
Coiz
1979 CJ7
Thread from the dead!
VACJ7,
Did you ever find a good replacement for that 4WD indicator connector? Or does anyone else know where to get one?
Mike
Coiz is offline
post #8 of 33 Old 06-17-2011, 06:43 PM
MoC
Any idea if its the same connector on the quadratrec tcase? If so I can cut it off my 360 donor waggy and mail it.
MoC is offline
post #9 of 33 Old 06-17-2011, 08:35 PM Thread Starter
VACJ7
VACJ7's Avatar
Mike, I did not. Dang thing is always falling off too. I used some small screw drivers to try to close the female connector and some dialectric grease and it held for a while.
Paul
VACJ7 is offline
post #10 of 33 Old 06-17-2011, 10:37 PM
MoC
Paul & Mike,
see if you can find out if they are the same as the quadratrec tcase. If so I have one one my 360 doner waggy and LSUtiger has on his 401 donor waggy. I could mail each one of yall one.
MoC is offline
post #11 of 33 Old 06-17-2011, 11:45 PM
Coiz
1979 CJ7
Hey MoC,
Don't you have a D300 in your CJ7? Can you cut it off your Waggy and see if it plugs onto your D300 switch? Or, take your switch out of the D300 and see if it plugs into the Waggy harness? I would assume they are the same but we all know what happens when you assume.
Mike
Coiz is offline
post #12 of 33 Old 06-17-2011, 11:51 PM
Rollbar
1984 CJ8
Couldn't you slide the slightly bigger on one, solder it, and then a heat shrink tube. Should work and the the solder wouldn't give off that much heat on the switch. Just a thought.
<----Click
<---- Click
Rollbar is offline
post #13 of 33 Old 06-18-2011, 05:17 AM
MoC
Originally Posted by Coiz View Post
Hey MoC,
I will check today and see what there is to see.
MoC is offline
post #14 of 33 Old 06-18-2011, 07:41 AM
supersport126
just solder it on
supersport126 is offline
post #15 of 33 Old 06-18-2011, 08:08 AM
petey156
why not take a smaller connector and stretch it out to fit with a nail or small screwdrive then put a small bit of silicone on it and push it on.
or take a larger one and use a cimping tool and give it a squeeze...
petey156 is offline
Need to find 3 wire neutral safety switch female pigtail connector skidplate77 Jeep CJ Forum 6 02-07-2010 03:48 PM
Where can I find a dimmer switch connector? Balvar24 Jeep CJ Forum 2 02-25-2009 03:47 PM
Stop light switch Connector TomCombo Jeep CJ Forum 2 02-24-2009 06:48 AM
T5 BU LIGHT Switch connector Wolf359 Jeep CJ Forum 1 06-03-2007 03:07 PM
Reverse Switch Connector dreski1 Jeep CJ Forum 2 10-30-2005 12:09 AM
