D18 question? - JeepForum.com
post #1 of 5 Old 12-22-2013, 04:06 PM Thread Starter
ridge28
1964 CJ5
D18 question?
I recently swapped out my samll hole dana 18 for a large hole dana 18 and my speedo isnt working after plugging it into the large hole. Are the speedo gear input different? Can i just swap the small hole speedo gear input into the large hole?
ridge28 is offline
post #2 of 5 Old 12-22-2013, 05:34 PM
DanStew
1963 M-38
you should be able to switch out speedo gear. Also i would recheck the speedo cable and make sure it is all the way in on teh speedo and on the tcase .
Dan Stewart
1991 Wrangler
DanStew is offline
post #3 of 5 Old 12-22-2013, 09:32 PM Thread Starter
ridge28
1964 CJ5
are they different speedo gears or the same? cause it the large hole one seamed bigger?
ridge28 is offline
post #4 of 5 Old 12-23-2013, 08:50 AM
DanStew
1963 M-38
I believe they are different based on the axle ratio. They should fit on the same shaft. If you have both, just get a caliper and see if the inside opening is the same.
Dan Stewart
1991 Wrangler
DanStew is offline
post #5 of 5 Old 12-23-2013, 09:24 AM
duffer
1955 CJ3B
What Dan said. Other than the actual case casting and the index, the small and large index D18's use all the same parts and the speedo gears should interchange. The only exception is the intermediate gear teeth counts/shaft sizes but that would not affect anything other than the intermediate/bull gears.
1955 CJ 3B, 381cid sbc (441cid all aluminum sbc coming soon), AGE M22W, Teralows, Warn OD, OBA, Premier Power welder, Warn 8274
1968 CJ 5, factory 225" w/ headers/450 cfm Holley, T86AA, Belleview winch, Warn OD
2012 Wrangler Rubicon Unlimited, Warn 9.5 xp-s winch
duffer is offline
