D.u.i. - JeepForum.com
post #1 of 8 Old 08-16-2013, 12:57 PM Thread Starter
b-dog
D.u.i.
been thinking about installing a D.U.I. distributor on in my cj. last winter i replaced my 258 with a rebuilt 304. everythink went pretty good had to get a few things from the junkyard like the distributor. my rebuilt 304 had points. so i pulled a distributor from a wagoneer and used it. it was a little cruddy looking but i cleaned it up and istalled it and it ran great. with the intention of atleast replacing the cap and rotor. never got around to replacing it. my question is how much differance do you guys think it will make. worth the $400. also if i just replace the cap i was going to install the bigger cap. but it looks like a light fit with power steering pump.
b-dog is offline
post #2 of 8 Old 08-16-2013, 02:00 PM
JoeDahero
1974 CJ5
Just my $0.02 but if you're expecting a dramatic difference and your current ignition is functioning properly you'll prolly be disappointed. I put a DUI in my 304 about two years ago. Was there a difference: yes. Was it huge and immediately obvious: no. For me it was worth it to eliminate the potential problems of points but others here will tell you you can get the same results cheaper through different methods. For me it was part of a process of elimination of potential trouble areas in my motor. As I'm just a shade-tree guy, the most effective method of engine troubleshooting is deductive reasoning and process of elimination. Along with all the other things I've done to it, my 304 is a sweet-running, reliable motor. The DUI is part of that but doesn't get all the credit. Ignition is just one piece of the puzzle. Research all the options out there and decide which way to go. For me the DUI made sense and I'm happy with it.
JoeDahero is offline
post #3 of 8 Old 08-16-2013, 02:08 PM
bradleybrb
1975 CJ5
Just my .02 but I would go with the DUI if I was going with an hei set up. That's based off the problems I have had with a cheaper hei that I bought.
bradleybrb is offline
post #4 of 8 Old 08-16-2013, 02:10 PM
jdarg
There's probably bigger gains in adjusting the curve on the waggy distributor. Its a heavy vehicle and that's probably reflected by a less aggressive advance in that jy dizzy. Then drop in a used MSD box. You'll be ahead of a DUI for less money IMHO.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #5 of 8 Old 08-16-2013, 03:36 PM
LSUtiger
1980 CJ5
Personally I thought the hei dizzy was to large for the v8. The cap is huge and it's close to the p/s belt which make adjusting the timing more difficult.
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #6 of 8 Old 08-16-2013, 04:49 PM
JeepHammer
Running On Empty...
1973 CJ5
This has been beat to death...
When you trade one factory system for another (in this case, Ford/DuraSpark for GM Clone/DUI) you are just swapping 'Issues'...
Joe hit the nail on the head,
Once you have eliminated the 'Problem' issues, both ignitions work about the same,
The difference is, the upgrade DuraSpark distributor is much easier and cheaper to do than pulling the distributor and starting over from scratch.
With Joe's situation, '74 had Prestolite or Breaker points, both sucked in a HUGE way.
Anything would have been an upgrade...
DUI was probably a viable swap for him, since he didn't have a reasonable distributor to start with.
B-dog has an '85, and that's a different story...
'85 has a DuraSpark distributor in it, and that is one of the most precise, easy to tune units on the market. VERY DURABLE, strong signal, and with a simple cap, rotor, plug wire upgrade, it will deliver high voltage as well as it manages the low voltage/timing advance.
Cap, rotor & plug wires are cheap, and need replaced every 20 or 30 years anyway! (or sooner if you want things to run correctly).
If you look in my signature line, you will find an upgrade link for the factory style ignition, and that might give you some ideas before you shell out your hard earned bucks on something you have to start from scratch with...
The choice is yours, We'll support you with either choice!
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #7 of 8 Old 08-16-2013, 05:24 PM
JoeDahero
1974 CJ5
Jeephammer- thanks for the props but for me it really came down to laziness. I read and re-read your write ups and posts on ignition and in the end it just seemed easier to spend the cash and drop in the complete DUI unit than to hunt up all the parts to do the Duraspark.
And FWIW your comments on Chinese clones and cam gears ultimately led me to spend the cash on the DUI rather than taking a chance on a cheaper setup.
The DUI was super easy for me. Did it on a Saturday afternoon and went without a hitch.
Bottom line - replace or improve or refurbish your ignition. Which ever way you go it'll be worth it. Don't expect a miracle but a bunch of little things can make a big difference all together. My 304 isn't remotely the same animal that came home on the trailer when I bought the CJ and I haven't done any major engine work or spent a ton of money.
Get it running RIGHT - then decide where to put money. Don't look for a magic bullet because there isn't one regardless of what DUI wants you to believe.
post #8 of 8 Old 08-16-2013, 11:37 PM
John N
1981 CJ8
The easy solution is to a 1" to 2" longer p/s belt. There's plenty of adjustment in the pump and it'll clear fine.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
