Cylinder misfire, Idle and accelleration. - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Cylinder misfire, Idle and accelleration.
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineOfficial Chassis Saver Rust Preventive Truck & Auto UnFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye Kit
Unread 04-12-2014, 04:24 PM   #1
qaiphyx
1979 CJ7
Have a cylinder misfiring and cant figure out the problem. New plugs, wires are good, timing is set, fuel mixture good. Misfires at idle and higher revolutions. Compression in all cylinders is good. Ideas?
1979 CJ 7 258 Carter Carb Electronic ignition.
Video of exhaust. Low idle
https://scontent-b.xx.fbcdn.net/hvid...cb&oe=5349DC50
qaiphyx is offline   Reply With Quote
Unread 04-13-2014, 05:20 AM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
What kind of plugs? Bosch platinum will fast carbon up and cause a miss.
I do a test for leaky plug wires by spray misting them with water while the engine is running in a dark place. Sometimes there are amazing light shows from this.
I next check inside the distributor cap looking for carbon tracks or crud.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Unread 04-13-2014, 07:49 AM   #3
Matt1981CJ7
Matt1981CJ7's Avatar
1981 CJ7
The video isn't working for me.
Assuming the ignition system is all good, the spark plugs are correct, and the timing is right, I'd be looking for a intake leak.
Matt
Matt1981CJ7 is offline   Reply With Quote
Unread 04-13-2014, 07:49 AM   #4
qaiphyx
1979 CJ7
It does it with both platinum and copper spark plugs, from what I can remember it also still had this problem when the dist and wires were brand new but ill do the spray test and see if I can find anything.
Any other ideas?
Could it be possible that the valves still need to be adjusted?
Unread 04-13-2014, 07:51 AM   #5
qaiphyx
1979 CJ7
Matt
Ill see if I can correct the issue.
Intake is good Ive already checked all the way through with leaks. Has new exhaust and intake gasket.
Unread 04-13-2014, 08:15 AM   #6
qaiphyx
1979 CJ7
basically it just goes mmmmPuhmmmPuhmPuhmmmPuh. doesn't run right seemingly either in the fact that it needs alot of rev to get going and well die out if I just slowly let the clutch out, maybe that's normal though?
Unread 04-13-2014, 08:32 AM   #7
Mike Romain
The valves are hydraulic, no adjustment other than tight.
I would be looking real close at the EGR valve too. A bad one that is sticky or a leaky one (had a foot rot off on mine so it was loose) can cause symptoms like you describe.
Mike
Unread 04-13-2014, 10:02 AM   #8
qaiphyx
1979 CJ7
Im not currently running an EGR Valve.
Thanks for the information on the valves. I highly doubt that one is loose.
Unread 04-13-2014, 10:22 AM   #9
Mike Romain
Could the cover plate for the EGR be leaking or is that non existent?
Mike
Unread 04-13-2014, 11:33 AM   #10
qaiphyx
1979 CJ7
spayed it with starter fluid, nothing. I opened a port in the manifold though and the idle went up, is this normal?
Unread 04-13-2014, 11:34 AM   #11
Mike Romain
Yes
Mike
