Currie Twin Stick Engagement - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Currie Twin Stick Engagement
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 08-13-2015, 08:34 AM   #1
sully122
1983 CJ7
I have a 83 CJ7 with a 350, 700R, D300 and a currie twin stick set up. I am having a heck of a time getting the twin stick to engage with the various 2WD/4WD HI/LOW gears. Anyone have a similar set up and if so any tips one easy engagement? There is a constant load on the D300 with the auto Trans contributing to the difficulty here however, there has got to be an trick to get the engagement to work easier.
Thanks
Dan
sully122 is offline   Reply With Quote Quick reply to this message
Unread 08-13-2015, 08:42 AM   #2
Erik719
Erik719's Avatar
1983 CJ7
I've had a few issues getting into 4LO.
Do you have the "full conversion"; with the pin removed inside the case? Or just the twin sticks? Mine is just the twin sticks.
'80 CJ7 - Gone but not forgotten
'83 CJ7 - Donkey
Erik719 is offline   Reply With Quote Quick reply to this message
Unread 08-13-2015, 09:21 AM   #3
CSP
Put the transmission in neutral or park, just like you would with a single stick.
CSP is online now   Reply With Quote Quick reply to this message
Unread 08-13-2015, 10:45 AM   #4
LumpyGrits
Cj
Even with the single 'stick' I have found it's sometimes necessary to backup 8-10' in a straight line to take the 'bind' off the drive-line.
Make sure the sticks are not hitting the tunnel to restrict movement.
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline   Reply With Quote Quick reply to this message
Unread 08-19-2015, 07:46 AM   #5
sully122
1983 CJ7
Thank you for your responses.. Backing up seems to make it a bit easier to engage the gears..
