A cure for bumpsteer maybe - JeepForum.com
post #1 of 24 Old 03-19-2009, 03:55 AM Thread Starter
BioTex
1979 CJ7
I have a bit of bumpsteer, but what bothers me the most is when I hit the brakes. I'm pulled to one side or the other depending on braking or accelerating. Doesn't feel safe.
I was under the front looking things over, and it looks like there is an installed lowered pitman arm, just not quite low enough. So I'm checking it out, and I'm wondering if swapping the steering rod from bottom to top would help.
I don't know the names of all the front end parts, but I'm talking about the rod that hooks to the pitman arm, and the runs to the pass. side wheel. It bolts on from the bottom, and if it were bolted on the top, the rod (whatever it's called) would be more parallel to the (other rod).
Sorry, I'm trying to learn what they are called. I heard the term drag link, tie rod, etc...
Has anyone tried this to solve bumpsteer? Maybe mine is on backwards to begin with...
Currently:
79 CJ7 "CJ Express" 4.2L, NV4500, D44 rear
69 800 with SBC, SM465, NP205, 14BT
BioTex is offline
post #2 of 24 Old 03-19-2009, 06:28 AM
CJ Chet
I put a "flip kit" on mine. Works real good, no bump steer at all. You need to have your tie rod and drag link as parallel as possible.
'86 CJ7
'04 AEV RUBICON
2015 Grand Cherokee Limited
CJ Chet is offline
post #3 of 24 Old 03-19-2009, 06:35 AM Thread Starter
BioTex
1979 CJ7
Why do you need a flip kit? Can't you simply just flip it? Are you talking about flipping at the pittman arm , or at the wheel end of the tie rod?
Currently:
BioTex is offline
post #4 of 24 Old 03-19-2009, 06:38 AM
Mike Romain
You are describing a blown wheel bearing or bad tie rod end or drag link end. I would be jacking up the front wheels and seeing if they flop around loose in all directions (bearing) or are loose in a right/left way which would be tie rod.
Putting a pry bar under the main ball joints to check them for play is also called for.
Bump steer is when the steering wheel dives to one side when you hit a bump, not a directional change in the Jeep under braking or acceleration, that is a bad part.
Mike
Mike Romain is offline
post #5 of 24 Old 03-19-2009, 06:41 AM Thread Starter
BioTex
1979 CJ7
My thought was that if I brake, the fron end dips down, and when I accelerate it rises. This I thought would do the same as hitting a bump. Is that wrong?
Currently:
BioTex is offline
post #6 of 24 Old 03-19-2009, 06:54 AM
Mike Romain
Yes, this is wrong.
You are just describing soft springs and maybe bad shocks with the nose diving or even unadjusted or bad back brakes. Directional changes are bad parts.
Bumpsteer involves the steering wheel, it violently jerks to the side when you hit a bump if you have that problem. I have about 1/2" of bumpsteer on really hard bumps.
Mike
post #7 of 24 Old 03-19-2009, 07:25 AM
CJ Chet
That won't work because those are tapered holes.
'86 CJ7
'04 AEV RUBICON
CJ Chet is offline
post #8 of 24 Old 03-19-2009, 07:55 AM
seventythree
1973 CJ5
this is the tie rod flip kit I used, easy cheesy
http://www.ok4wd.com/index.php/catal..._rod_flip_kit/
73' CJ-5. 98' Mustang Cobra, 03' Silverado SS,
87' Landcruiser FJ60, 05' Kawasaki Brute Force 650
86' Honda XL250R, 00' Toyota Epic X22
seventythree is offline
post #9 of 24 Old 03-19-2009, 02:46 PM
PavementPounder
Cool as Ice...
PavementPounder's Avatar
No, that's not "wrong", but that's not what's most likely happening. If your drag link is at a downward angle and your suspension compresses (assuming the steering wheel is held still) the 2D cross-car distance (straight horizontal, not point-to-point) between the end of the pitman arm and the knuckle grows (since the drag link is a fixed length), pushing the passenger knuckle to the right. That's exactly what bumpsteer is. It can come back through the steering wheel - just depends on the path of least resistance. It can technically cause the conditions you are experiencing, but its less likely that your nose is diving far enough to cause this upon braking than it is that you may just have a worn component somewhere.
If your nose is diving and rising a lot, you may also have an unrelated worn shock problem on top of whatever else is going on that would amplify the problem. If you think its too much, replace the shocks. it will help you isolate the problem.
The tie-rod flip is a great solution for getting your drag link more horizontal when a dropped pitman arm is not enough as long as your spring configuration and drag link geometry will accomodate it. As CJ Chet said, the holes in your steering arms are reamed from the bottom up. Some tie-rod kits account for this and come with inserts so that the kit is a true bolt-in, but some of those kits are comprised of hybrid tie-rod ends that look like they are beefy, but actually have a rather small stud and joint.
If you aren't satisfied with the bolt-on kits due to the marginal increase in strength, the other solution (that I call the "real" one) is to use true 1-ton GM TRE's (that you can buy at any parts store) and ream out the steering arms from the top-down. JCR Offroad actually has all the part numbers listed on their site for the DIY'er. You'd just buy the ends and rod that you need for a CJ's crossover system instead of the driver's one shown for the inverted-t:
http://www.jcroffroad.com/Merchant2/...tegory_Code=S6
<--- Click "Classifieds" under my avatar to see all my parts (mostly CJ & XJ) currently for sale on JeepForum!
PavementPounder is offline
post #10 of 24 Old 03-19-2009, 02:55 PM Thread Starter
BioTex
1979 CJ7
I'm going to have to rule out the shocks, since they are new Rancho's. The bumpsteer I'm experiencing is only when I hit the brakes fairly hard, or accelerate quickly. I looked at the link you provided, and I don't want to spend that much right now, so I will try the flip kit with reamer for around $85 that seventythree used. It should do the job. Before I order it, I want to make sure it won't put me in the same boat, only the other direction. That would suck! Thanks for the help.
Currently:
BioTex is offline
post #11 of 24 Old 03-19-2009, 03:13 PM
gwolff
1978 CJ7
Look at Goferit's tierod flip kit. Alot less$.
Check me if I'm wrong, but if you still have the straight OEM pitman arm, you should be able to flip it, but then the angle would be even worse.
Or, is it already flipped wrong?
gwolff is offline
post #12 of 24 Old 03-19-2009, 06:35 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Some diving under hard braking is normal. So is front end rise under hard acceleration.. especially if you've got an engine with some power.
The closer to "horizontal" you can get with your drag link, the less bumpsteer you'll have. However, most rigs can tolerate a couple inches of drag link drop (angle) without much bumpsteer under normal driving... especially with the longer drag link used in crossover steering (like our CJs).
BESRK is offline
post #13 of 24 Old 03-20-2009, 05:18 AM Thread Starter
BioTex
1979 CJ7
I have a dropped arm, just not dropped enough.
Currently:
BioTex is offline
post #14 of 24 Old 03-20-2009, 05:21 AM Thread Starter
BioTex
1979 CJ7
I will get some pics later, but also I will jack up the fron and check bearings and tie rods. It just occured to me I haven't done that yet. I have been pretty caught up in the engine swap.
Currently:
BioTex is offline
post #15 of 24 Old 03-20-2009, 05:46 AM
twoleos617
what size pitman arm do you have? Your 4" BDS kit uses a 4" drop pitman right? or, b/c you flipped your tie rod and drag link, did you get a shorter pitman to compensate?
twoleos617 is offline
bad cj bumpsteer badady1 Jeep CJ Forum 16 05-23-2008 08:32 PM
Silicone Dry/Cure Time? Jack-Jack Jeep CJ Forum 3 09-27-2005 09:04 AM
CJ7 Frame Crack cure? Muttley Jeep CJ Forum 2 10-09-2003 09:19 AM
