cummins swap - JeepForum.com
post #1 of 7 Old 01-21-2011, 08:54 PM Thread Starter
MooseMarine
JP'N MTBR
MooseMarine's Avatar
cummins swap
i have a 59 CJ5 willysX and i wanna put a 97 5.9 12 valve in it. Is it even possible without losing a lot of cab space?
You are the average of the five people you spend the most time with.
_______
/| ,[____],
|---L '[]lllllll[]'
()_)-()_)--o-)_)
MooseMarine is offline
post #2 of 7 Old 01-21-2011, 08:56 PM
ajf1994
IMO, just do a 4BT...
-SupportOurTroops-
High School Jeepers #361
Parrothead Jeep Club #46
37,xxx Miles
Originally Posted by XJ-Tim View Post
my welds look like popcorn with sprinkles.
Originally Posted by Benjamin Franklin
Beer is proof that God loves us and wants us to be happy.
ajf1994 is offline
post #3 of 7 Old 01-21-2011, 09:05 PM
benullman
1981 CJ7
theres one in every crowd.
if you REALLY wanted to make a non-unique jeep put a SBC in it!!!
Id get the tape measure out and see what you got!
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #4 of 7 Old 01-21-2011, 09:14 PM
Trapshooter
Make sure you calculate the weight you'd put on the front end with that engine. It will be a ton.........
'86 CJ7, 258, Carter BBD, Nutter'ed, TeamRush'ed, T-18, Twin Sticked Dana 300, D30 Frt-Pwr Lok L/S-4.10, AMC 20 Rear-Mosers-Detroit Locker-4.10, 2.5 BDS Lift, 1" Body Lift, 33" Wild Country M/Ts, Black Spoke wheels
'45 CJ2A, L134 Go Devil, T-90 Tranny, Warn O/D, T-18 T-Case, Dana 25 Frt, Dana 41 Rear, 531st CJ made
My 401 build:
Trapshooter is offline
post #5 of 7 Old 01-21-2011, 09:39 PM
HotStuff
That 12valve has a weight of close to 1300# give or take, with all the accessories on it. The frame,and driveline won't handle that weight, or the torque. And I'd bet it's too long (I6) to fit under the hood without severly chopping the front of the tub out. The reason they went to the longer nose in '71 (?) is to put the Jeep I6 engine in. And the Cummins is quite a bit bigger yet. Just my opinion, either do a 4BT, or a v8 swap. Easier, and less expensive when you start to factor the driveline/frame requirements.
'96 XJ 6.5" lift, 33's, HP30, 8.8", 4.56's, 4wheel disc, spooled rear, locked front, SYE, skids, yada yada yada.'51 Willys CJ3A 32's, 5.38's, locked front & rear, small block, Muncie 4speed.'76 CJ5 - UNDER CONSTRUCTION - resto/mod
HotStuff is offline
post #6 of 7 Old 01-21-2011, 09:56 PM
jpywell52
1979 CJ7
my .02, if you are looking for diesel find a smaller 4 cylinder out of an Isuzu. They are great motors in my experience. Had one in an old Chevy LUV and it was bomb-proof and had no problem towing a couple thousand pounds of garbage on a single axle trailer when i loaned it to a friend who was rehabbing his house (the brakes weren't really up to it though. They were also used in troopers i believe which would make finding a trans/case configuration for the jeep easier. And if you need more power throw a turbo on it.
jpywell52 is offline
post #7 of 7 Old 01-21-2011, 09:58 PM
jpywell52
1979 CJ7
Also I agree with hot stuff, you'll be pulling a nose wheely ever time you hit the front brake with that much weight forward and it will take some really stiff springs to compensate making the ride even harsher.
Official Cummins 4BT Swap Thread for CJ-7's BigTorqueCJ Jeep CJ Forum 319 09-23-2014 06:29 PM
Your opinions: complete 4.0 swap or just 4.0 head swap? '83Laredo Jeep CJ Forum 9 05-22-2011 05:04 AM
Pros and cons of 360 swap versus 304 swap SilverRubiSC Jeep CJ Forum 19 10-12-2009 11:36 PM
Cummins Willys Radiator Issues 1952m38a1 Jeep CJ Forum 0 03-01-2009 05:32 PM
Tranny swap now with future engine swap in mind gestuhlm Jeep CJ Forum 1 04-23-2006 07:49 PM
