CTO Valve,PVC and Weber 32 36 - JeepForum.com
post #1 of 7 Old 12-09-2009, 05:31 PM Thread Starter
chuckwag
1981 CJ5
I removed the cto valve and can't find it, I ran the pcv right into the carb via the booster connection and got blue smoke, then i ran the front pcv into the bottom of the weber air clean and got no smoke but a little blow by of the rear valve cover. I got 50-60 pds of oil pressure when driving, no problem there.
Can anyone offer any info on how i can reroute the pcv front and rear so i don't have any blow by, or can i purchase another cto at a parts house or find a used one around. thanks
chuckwag is offline
post #2 of 7 Old 12-09-2009, 06:10 PM
keith460
Jeep. There's Only One
keith460's Avatar
A little confusing in what you are saying. There is only "one" PCV valve usually located in the front grommet hole on the valve cover. The rear grommet hole is for fresh air intake from the air filter that supplies are that is drawn out by the PCV valve connected to full manifold vacuum.
The CTO valve is nothing more than a thermal switch that allows vacuum to pass through it once the engine coolant warms to a certain temperature. The PCV valve does not connect to the CTO valve. The EGR valve is connected to the CTO after the vacuum source goes through an ambient air thermal switch located in the air filter housing.
1984 CJ-7 Renegade
keith460 is offline
post #3 of 7 Old 12-09-2009, 06:34 PM Thread Starter
chuckwag
1981 CJ5
I understand what you are saying, the back inlet on the valve cover is basically for the fresh air in and should be hooked up to the air cleaner, but if I hook the pcv into the vaccum on the carb I get blue smoke, there is a diverter in the valve cover, so its not oil splashing into the pcv valve
the question is were can i hook the pcv into to draw enough air threw the valve cover, so the engine doesn't smoke. If I go threw the booster nipple into the intake the engine smokes
chuckwag is offline
post #4 of 7 Old 12-09-2009, 06:43 PM
keith460
keith460's Avatar
You got something else going on there then and probably need a new PCV valve and change your oil more often.
A supplied adapter plate for the Weber carb has a brass nipple for hooking up the PCV valve hose to as pictured.
The system consists of a small air intake breather hose mounted in the intake tract before the throttle body, and the PCV valve, which is typically in the intake manifold or the valve cover. Air flow is from the breather before the throttle body, through the crankcase, up the PCV valve and into the intake manifold after the throttle body. It's basically a controlled air leak, with the PCV valve acting as a one-way check valve that has adjustable flow characteristics.
If the PCV valve gets plugged, here's what happens, roughly in order:
1. Excess crankcase pressure begins to back up the engine's breather tube, into the intake air tube upstream of the throttle body
2. Oil begins to be pumped into the air intake tube through the breather hose, upstream of the throttle plate.
3. Oil runs down the intake tube into the throttle body.
4. Oil sludges up the throttle body and throttle plate. Gas pedal starts to get sticky. Airflow reduced. More power loss, possible poor driveability.
5. Oil drips into intake manifold runners. Blue smoke seen out of tailpipe.
6. Breather tube begins to get constricted from oil contamination and airflow is reduced. Crankcase pressure mounts dramatically.
7. Oil pushed past valve guide oil seals. More blue smoke.
8. Dripping on driveway as oil is pushed past seals.
1984 CJ-7 Renegade
keith460 is offline
post #5 of 7 Old 12-09-2009, 06:51 PM Thread Starter
chuckwag
1981 CJ5
the pic helps, so tieing into the canister helps the volume of gases coming from the head out into the pcv, I would assume that the smoking would stop. or do I have to much pressure coming from the engine into the valve cover and then into the vaccum line
chuckwag is offline
post #6 of 7 Old 12-09-2009, 06:57 PM
keith460
keith460's Avatar
I added to the post with the picture.
1984 CJ-7 Renegade
keith460 is offline
post #7 of 7 Old 12-09-2009, 07:10 PM Thread Starter
chuckwag
1981 CJ5
thanks keith, I do understand whats being said, I think the nipple might be to big for the manifold vaccum, I will re-route it all tomorrow and down size the intake nipple. the pcv is new, the engine was recently rebuilt. I think the manifold was getting way to much of the engine vapor causeing it to smoke. Plus I need to change the oil, the engine is still breaking in. thanks
chuckwag is offline
Replacements for Liquid Check Valve/Roll Over valve jpd1899 Jeep CJ Forum 143 08-25-2015 09:07 PM
Changing valve cover gaskets/valve covers gtrpup2 Jeep CJ Forum 20 03-28-2013 07:35 PM
Brake Combination Valve/Proportioning Valve Question Wrangler1642 Jeep CJ Forum 1 01-17-2011 04:43 PM
PCV valve and leaking valve cover hole crrushing Jeep CJ Forum 2 02-08-2010 05:44 AM
Weber 32/36 Power Valve Hunt_Nevada Jeep CJ Forum 0 07-21-2006 08:58 PM
