CRT HEI cam gear question - JeepForum.com
post #1 of 114 Old 05-09-2008, 11:06 AM Thread Starter
BioTex
I just installed a new CRT Performance HEI system on my 85 258 I6. After reading some posts in this forum, I realize there are some cheap imports that can cause the cam gear to wear. Does anyone have any knowledge as to the quality of the CRT? I would rather replace the dist. than to have to replace the cam.
Isn't this soooo much fun?....
'85 CJ7, BDS 4" lift, 1" Body lift, 33x12.5, Shrockworks Sliders, 304 V8 with RV cam., T-176, D300, Dana 30, AMC 20.
06' TJ Rubicon, 4" R.C. springs, BFG/AT 35s M.C. 6" fenders, rockers and surrounds, Currie front & rear adj. tracbars, tattons DC rear shaft, adj. upper - lower CA's. Bilstein 5100's
Current project. Stroker/FI ?
1990 MJ Comanche 4.0L AX15/np231
BioTex is offline
post #2 of 114 Old 05-09-2008, 11:21 AM
dirtbagofva
2010 JK Wrangler
From thier pictures they seem to be using STEEL gears. I know that my cam gear is iron (81 AMC-V-8)...not as strong as steel. You can buy a Malory bronze gear ($80) or re-use your old gear from the old Distibutor.
You can test the hardness os the 2 gears by trying to scratch them with a nail on an unimportant surface (16p is a good size). If the result is the same on both gears you fine.
I am currently fixing the shreaded cam gear in mine. FYI the gear on the cam is removable.
Robert
"It is a damned poor mind indeed that can't think of at least two ways of spelling any word."
Proud owner of 2010 JK, 1994 XJ and an 81 CJ-7
dirtbagofva is offline
post #3 of 114 Old 05-09-2008, 11:28 AM Thread Starter
BioTex
I am probably wrong, but think I remember readin a post where you have to modify the original gear in some way to reuse it. Is this correct, or will it just work as is. Do you think I should not take any chances, and replace it with my original?
BioTex is offline
post #4 of 114 Old 05-09-2008, 11:37 AM
dirtbagofva
2010 JK Wrangler
some drilling may be reuired to fit the roll pin. not real difficult with a drill press. be sure to pien the pin once it is installed to keep it from coming out.
post #5 of 114 Old 05-09-2008, 12:55 PM Thread Starter
BioTex
So, by your reply are you recommending I go ahead with the gear swap to be on the safe side? I just finally got the timing tweaked so I don't have "pinging". Kind of hate to remove the distributor again, but I guess it's better safe than sorry in this case.
BioTex is offline
post #6 of 114 Old 05-09-2008, 02:26 PM
JeepHammer
Running On Empty...
1973 CJ5
OK, for the orignal question...
Yes, there have been some complaints about CRT gears here.
The only way to test for sure if it's steel or iron is to chuck up about an 1/8" drill bit, and drill into the apron of the gear about 90 from the pin hole.
If it drills easily, it's iron...
If it drills hard, it's probably the Spanish hardened steel gear and you shouldn't use it.
Then all you have to worry about is if the guys that made the gear did the tooth profile correctly.
Some of the Mexican iron gears had the wrong tooth profile, but were at least iron...
The I-6 engine has the cam gear cut into the cam it's self,
While the V-8 has a removable gear at the end of the cam.
SO,
If you are going to use a aftermarket gear on a I-6 cam gear, you had better make every effort to be 'Correct' or your cam goes away...
One other thing to clear up,
The gear off your '85 factory distributor WILL NOT fit on on most aftermarket HEI clones... So there is no "Using the old one to be safe".
You will have to measure your distributor shaft. Most HEI clones aren't even close to factory GM HEI size, but you might get lucky and if you do, I can give you the part number for the correct gear for your application.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #7 of 114 Old 05-10-2008, 03:23 PM
godrocksus1
So I have an original chevy HEI Dist (82 chevy pu). can I use the gear off my original 258 distributor?
godrocksus1 is offline
post #8 of 114 Old 05-10-2008, 04:00 PM
JeepHammer
Running On Empty...
1973 CJ5
Like I just said,
NO, YOU CAN NOT USE A GM GEAR, THEY TURN THE WRONG WAY.
NO YOU CAN NOT USE THE MOTORCRAFT GEAR ON AN HEI...
The shafts are not close to being the same size, so there is no using the old gear in this case...
Measure the shaft and use a proper size gear,
NAPA/Echlin p/n DG 400, DG 401 or DG 402 should work.
This is the correct gear for your AMC engine on a Delco distributor shaft.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
post #9 of 114 Old 05-10-2008, 06:23 PM
jaykump
jaykump's Avatar
1974 CJ5
I just bought a HEI dist. from 4WD along with a new cam gear from the same place......30 miles later I don't have a cam gear.....has anyone else had issues with 4wd Dist.? I bought theirs instead of ebay cuz I had faith in them.....need to wait until Monday to find out what they will do
Anybody know if MSD gears will work on this HEI?
1974 CJ5 360 Bored/Balanced T150 3speed/Dana20 t-case, Dana 30/44 3.73 gears 4" lift. 33X12.50 BFG Mud Terrains Fiberglass body
jaykump is offline
post #10 of 114 Old 01-03-2009, 02:59 PM
CALICONOTTS
1987 YJ Wrangler
Crt Hei?
SO,
So am i to understand that the CRT's comming from North-east america have a cheap steal cam gear that basicly shaves off the cam gear?.
and the only way to prevent damage is to replace the cam gear.
i have a 4.2 with a standard cam, could you give me a part number for the exact gear i require to put on this CRT please, sir?
thanks
mike
i ordered it last week and just have to stop this brand new engine running like it is.
CALICONOTTS is offline
post #11 of 114 Old 01-03-2009, 08:16 PM
dodchall70
So, if the gear is one of the bad ones on a CRT dist, how long do you think it will take to tear up the cam gear?
85 CJ7, 258, Howell Fuel Injection, CRT Performance HEI Dist., 2" lift, Warn winch
Colorado Jeep Club Member #75
dodchall70 is offline
post #12 of 114 Old 01-03-2009, 08:31 PM
lucdog
1980 CJ5
dist
jaykumph, did you buy the hei dist thats about $150.00 or did you get the DUI dist thats closer to $300.
bill g.
lucdog is online now
post #13 of 114 Old 01-03-2009, 10:03 PM
foggybottombob
I used a junkyard chevy HEI and changed the gear to the one from an AMC 360 V8.
This next line is a quote from the url below. I don't remember where I ordered my gear but it was not a jeep dealer.
"The MOPAR number is 3208615. I called the local NAPA shop and got it for $32."
http://keith.cj8.tripod.com/hei_upgrade.htm
foggybottombob is offline
post #14 of 114 Old 01-03-2009, 10:28 PM
Fjguercio
1978 CJ7
JeepHammer speaks the truth.... reading thru the post further and see he is already on the ball. Sorry to say this is a awfull situation for our AMC engines.
Sorry...
You can test the hardness os the 2 gears by trying to scratch them with a nail on an unimportant surface.
I would suggest when testing the Distributor Gear, you try to drill with a std drill bit. If it drills easy then ok to use. The only Distributor Assemblies that I have heard are good are MSD & DUI. Any ebay stuff or others are roll of the dice, and there area other problems besides gear hardness. Shaft diameters vairy, lengths vary, arc to ground paths, wrong cuts on gears are other current problems. So a search and has been posted many times. Can also bind the oil pump and cause failure due to no oil
MSD sells the cam gears for different shaft diameters in the correct materials.
The V8 cam gear can be removed. The I6 like the poster has a one piece cam and the gear cannot be removed. Again the cam gear cannot be removed from the I6 258 and 232.
Be carefull with the HEI Distributors, you can kill your engine, and I kring about the idea of all that hardened metal in my engine internals.
Regards,
Fred
Fjguercio is offline
post #15 of 114 Old 01-06-2009, 09:37 AM
CALICONOTTS
1987 YJ Wrangler
OK People, time to cut the bull****, ive spoken with CRT, hes a dude thats been building these dist's for time, hes American. He's given me his word that its all a load of bollocks! about the steal gear.
He really wants to know who started this horse-**** so he can give them a damn good thrashing, in all honesty.
the gear that comes on the CRT is iron, hes even given me a part no-
Rockwell Hardness 50-55 HRC.
and its made in THE USA!.
The part is on its way, im a service writer at a auto repair center, ill have the part inspected, and ill post some pictures and a review and clear the air on this part and CRT.
Please, make the forums more use than just a descrimination center of product sales.
wait for my response, lets all know for sure what we are buying at my expense.
cool?.
gear question? NVRDUN Jeep CJ Forum 3 04-28-2009 12:24 PM
Gear question sgilmo2 Jeep CJ Forum 20 02-08-2007 05:05 PM
gear question now thenubsterman Jeep CJ Forum 8 09-30-2006 10:51 AM
gear question sgilmo2 Jeep CJ Forum 1 05-24-2006 10:53 AM
Gear set question 390fastback Jeep CJ Forum 10 10-28-2004 06:42 AM
