Crown Windshield rubber - JeepForum.com
post #1 of 25 Old 07-27-2013, 02:37 PM Thread Starter
CJ7ROB
no fit..Anyone else have this issue?
CJ7ROB is offline
post #2 of 25 Old 07-27-2013, 03:33 PM
jeepwhore
Haven't used one, but I can't say I'm surprised......it's a Crown part!
'84 CJ-17: 17" stretch, locked Toy axles, 5.5" lift, FI, AX15, D300 w/twin sticks, boatsides & junk.
jeepwhore is offline
post #3 of 25 Old 07-27-2013, 03:36 PM
skizriz
1978 CJ7
Looks the Same as my Crown did.
Sent from my HTC One SV using JeepForum
skizriz is offline
post #4 of 25 Old 07-27-2013, 10:02 PM
Skerr
YOW! That's pretty bad! Got mine from Q-tec... don't remember what the brand is, but it fit just fine. Got a second one for my son's Jeep. It fit too. Where'd you get yours?
Kerrdog
Go Fish! <*////><
Skerr is offline
post #5 of 25 Old 07-27-2013, 10:24 PM
MoC
Wow, that's really off. Wonder if it was mis packaged and for something else.
MoC is offline
post #6 of 25 Old 07-27-2013, 11:43 PM
Cutlass327
1978 CJ5
I have one just like that lying around somewhere. It cost me my OEM glass. I took the frame and seal to a glass shop, and they had to order one thru their supplier since it didn't fit. I would recommend the extra $$ to get one from a glass shop. I have a hard time trusting Crown parts anymore.
Rick
Cutlass327 is offline
post #7 of 25 Old 07-28-2013, 12:12 AM
MoC
I can't imagine that the glass shop can get one any different than we can get. I guess the only difference would be the shop would be responsible for getting another if it didn't fit.
MoC is offline
post #8 of 25 Old 07-28-2013, 02:42 AM
I6CJ7
Make sure your drive through some good rain to test the fit once its installed... Apparently jeep engineers knew how to properly seal the windshield 30 years ago. But today a shop even with modern sealants cant frigging do it... My windshield has been redone and sealed twice and it still leaks water when im driving in the rain.. Not sitting still, bit driving somehow forces water into the windshield gasket and then pours all over my dash and feet... And trust me, its not the cowl gasket..
I6CJ7 is offline
post #9 of 25 Old 07-28-2013, 06:51 AM Thread Starter
CJ7ROB
I bought this one at 4wd.com. I guess I'll give them a call about it or see if Omix makes one. I called 3 auto glass places. None of them want to use my windshield..which sux. I like mine b/c it has like the factory green tint to it. JC Whitney has one made by Garage Pro..anyone have any experience with that rubber? I'd almost take a good used one at this point ..thx guys.
CJ7ROB is offline
post #10 of 25 Old 07-28-2013, 08:10 AM
Skerr
Good luck, Rob. And the above statement is true on both our CJs! Thought it was just us. One glass I installed, the other done at a shop, both leak water around the seal, past the metal lip of the frame. The gasket does not make a water-tight seal to the glass. Maybe something to watch out for...
Kerrdog
Go Fish! <*////><
Skerr is offline
post #11 of 25 Old 07-28-2013, 09:37 AM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
Kent Automotive Glass Mastic. Exactly what it's made for.
I asked a ref if he could give me a technical foul for thinking bad things about him. He said, of course not. I said, well, I think you stink. And he gave me a technical. You can't trust em. -
Jimmy V
Pacfanweb is offline
post #12 of 25 Old 07-28-2013, 09:38 AM
Cutlass327
1978 CJ5
I figure the glass shop actually gets their stuff from a part supplier that is more quality controlled. I could picture the Crown part being the 2nds or whatever...
When the OEM glass broke, I ordered a new one thru the glass dealer and they asked if it was tinted or not. The replacement is green tinted too. I was happy about that.
Mine is leaking too, but I attribute that to the fact that I couldn't get the seal to fit in perfectly. I have raised up sections in the corners where the seal bends and opened up from the glass. I have worked some silicone into it, but now I'll have to do the same to the outer seal against the frame because it does seep some in heavy rains now. Its not as bad as before I sealed the glass part, but it does bug me that it still leaks...
Rick
post #13 of 25 Old 07-28-2013, 11:12 AM
SoK66
2009 JK Wrangler
I've had this happen enough with Crown to vow never to buy their junk again. Bummer.
SoK66 is offline
post #14 of 25 Old 07-28-2013, 12:18 PM Thread Starter
CJ7ROB
Is that a manufacturer? I've done these types of windshields before so I'll attempt it again as long as I have the right rubber.
CJ7ROB is offline
post #15 of 25 Old 07-28-2013, 12:30 PM Thread Starter
CJ7ROB
Edit: Gotcha that's the sealant.
CJ7ROB is offline
