crossmember mounting to frame and transmission mounting to crossmember problems. - JeepForum.com
post #1 of 4 Old 12-03-2002, 05:34 AM Thread Starter
77mudder
Question crossmember mounting to frame and transmission mounting to crossmember problems.
I have a 77 CJ7. It had a V-8 T3 and D20. now i am installing a
I-6 T176 D300. my problem is that no matter which way i try i can not get the crossmember to mount to the frame and be able to mount the transmission to that crossmember without riggin something up. I would rather not do that but unless there were different crossmembers for the different years then I don't know why it isn't bolting up together. Does anybody know how exactly to mount that tranny to the crossmember. I am trying to use a polyurethane mount but the stablilizer isn't coming anywhere near the transmission mount. thanks for the help.
stuff not together yet
almost done
77mudder is offline
post #2 of 4 Old 12-03-2002, 07:13 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
You pretty much answered your own question. When Jeeps started using the Dana 300, they also changed tranny crosmembers to that one that dips down on the passenger side. The older one you have is pretty much flat and interferes with the Dana 300 drop? I would cut, hack, beat, and weld it to make it work but that's just the kind of person I am. Besides, it' only metal . Otherwise pick up a used crossmember from an 81-86 and you should be good.
BESRK is offline
post #3 of 4 Old 12-04-2002, 06:08 AM Thread Starter
77mudder
crap
well mine has a big hump in the front section then two small humps that aren't for anything. do you happen to know if you use stabilizer bushings on this tranny? nothing interferes with the D300 drop it just is like 3 inches too short or 3 inches too long depending on if i slide the crossmember forward or back.
almost done
77mudder is offline
post #4 of 4 Old 12-04-2002, 09:10 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Not exactly sure on how the stock TC is setup. I mounted mine without any type of torque arm and haven't had any problems... yet.
BESRK is offline
Rubber bushings between crossmember and frame rail? Coiz Jeep CJ Forum 2 09-27-2008 03:49 PM
Crossmember issues with new frame jfrdog Jeep CJ Forum 1 08-05-2008 10:13 PM
Transmission Crossmember Blugrass19 Jeep CJ Forum 2 02-12-2007 07:48 PM
frar frame crossmember TUPPERCJ7 Jeep CJ Forum 1 02-10-2005 11:23 PM
Rear Frame Crossmember Search!! JeepTrickz Jeep CJ Forum 4 08-21-2001 10:37 PM
