Cross member - JeepForum.com
post #1 of 5 Old 07-03-2008, 06:03 PM Thread Starter
EDs Jeep
Cross member
How bad is it to replace rear cross member with body on. 85 Cj7 Thanks Ed
EDs Jeep is offline
post #2 of 5 Old 07-03-2008, 06:27 PM
jeepskate
Well, the body is mounted to it and there's welds on the top side of the frame to help hold it on...
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 5 Old 07-04-2008, 12:09 AM
only in a jeep cj
What you should do is either remove the body to gain access OR remove the body mount bolts to place spacer blocks between the tub and frame. I would raise it at least 8 inches in the back and use all thread in two of the body mounts to keep the tub in basic alignment. E brake cable should be OK and gas tank will need to be removed of course....the shifter/tunnel cover will need to be addressed though. Rear shackles may get in the way and need to be remove to allow spring to hang down (jack stands under frame just ahead of rear spring main eye).
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 5 Old 07-04-2008, 07:00 AM Thread Starter
EDs Jeep
Thanks guys just was trying to figure a way to repair this without removing all the mounts and opening up another can of worms. Ed
EDs Jeep is offline
post #5 of 5 Old 07-04-2008, 09:01 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've done it before with the tub on.. it was a PITA. I hacked off most of the crossmember (plasma/sawzall/air chisel) and then used an air chisel to break the weld on top of the frame.
BESRK is offline
rear cross member jeepcrazy83 Jeep CJ Forum 11 08-13-2009 07:44 AM
Transmission Cross member jmna Jeep CJ Forum 9 12-28-2008 05:26 AM
Automatic Mount/Cross Member JohnFM3 Jeep CJ Forum 5 08-21-2007 08:53 AM
Frame cross member rosco96 Jeep CJ Forum 0 08-06-2007 06:17 AM
what is the secret cross member bolts??? onehundred Jeep CJ Forum 6 12-02-2005 08:01 PM
