Crazy legs video (articulation) - JeepForum.com
post #1 of 13 Old 01-11-2010, 05:45 PM Thread Starter
Totallymetal
Thought this was worth sharing.
YouTube - Chainlink extreme 4x4
2007 JK Rubicon
5.5 Rock Krawler X-factor lift w/37 x 12.5 x 17 BFG KM2s, 5.13 Superior gears
Warn Powerplant HD
Totallymetal is offline
post #2 of 13 Old 01-11-2010, 05:48 PM
MoC
Crazy indeed..
MoC is offline
post #3 of 13 Old 01-12-2010, 05:42 AM
twoleos617
good lawd!
still havent figured out how each wheel gets power. must have a drive shaft going to each corner (but how?) into independenat pumpkins? chain or belt driven? ive never seen anything like that before!
im impressed!
Torque is the measure of force that gets the cap off your beer.
Mike D.
twoleos617 is offline
post #4 of 13 Old 01-12-2010, 05:49 AM
bfaneros
saw that a few days ago ... crazy
bfaneros is offline
post #5 of 13 Old 01-12-2010, 06:12 AM
Bow-hunt-er
1978 CJ7
Thats just plain cool
1978 CJ7, AMC360, D30 front, D44 rear, lock-rite lockers front & rear, 3.73 gears, Dana 20 transfer, T-18 4speed tranny
Bow-hunt-er is offline
post #6 of 13 Old 01-12-2010, 06:18 AM
Area.3.Fiftyone
I'm speechless.
That's the coolest thing I've ever seen.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #7 of 13 Old 01-12-2010, 06:20 AM
qwik
Wonder $$$,$$$,$$$.00 to build
00 wrangler sport. forest green. n_6. auto
qwik is offline
post #8 of 13 Old 01-12-2010, 07:10 AM
rixcj
rixcj's Avatar
1979 CJ5
That is an engineering marvel! What that does, is allow you to get stuck in places that no one else can get to, to retrieve you....
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is online now
post #9 of 13 Old 01-12-2010, 07:28 AM
Bow-hunt-er
1978 CJ7
[QUOTE=rixcj;you get stuck in places that no one else can get to, to retrieve you....[/QUOTE]
So true
post #10 of 13 Old 01-12-2010, 08:16 AM
southshore30
1982 CJ7
I was thinking the same thing towards the end of the clip when he was in that ravine and somebody said those are 39 and halfs. He would need to get helicoptered out of there! That thing is sick!
southshore30 is offline
post #11 of 13 Old 01-12-2010, 08:23 AM
TRex
1979 CJ7
That is one wild suspension. Seems like the engineering theory is sound-- just need to make it more "user friendly" and the military and NASA would be knocking at his door.
1979 Jeep CJ7
Follow My Build Thread: http://www.jeepforum.com/forum/f8/1979-cj7-build-project-trex-935022/
TRex is offline
post #12 of 13 Old 01-13-2010, 12:06 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Read the little description beside the video - a 9" in the center with chain drive to each wheel...
Cams hydraulic Chain-drive 4x4, about 7 feet of up OR down motion on each tire: specs below Engine is a fuel injected Ford 5.0 V8 out of a '93 cobra mustang, c4 transmission and t-case out of an early bronco. 9" w/ 5.38 gears and ARB air locker mounted in the center (below driver) running chain gears on the ends where the swing arms pivot. Swing arms are hydraulically controlled individually or together, and there is coil spring and shock suspension as well. large chains running inside the swing arms turn hummer gear reduction (2:1) hubs at each wheel. tires are 39.5". The steering is linked through the swing arms as well and the steering box is mounted just infront of the axle below the driver. body construction is steel tubing (mostly DOM) and the total weight is 5900 LB.
Rick
Cutlass327 is offline
post #13 of 13 Old 01-13-2010, 02:02 PM
trailhead2004
1980 CJ7
Originally Posted by twoleos617 View Post
good lawd!
im impressed!
I'm guessing hydraulic drive, but the speed on the one shot is pretty high so I'm not sure.
trailhead
"Bad things happen to you because you're a dumba$$"
Red Foreman
trailhead2004 is offline
no articulation.... jlutsey Jeep CJ Forum 17 05-24-2007 10:29 PM
lift and articulation NJCJ7 Jeep CJ Forum 1 12-22-2003 12:44 PM
guys check out this crazy video!! rwcloukey Jeep CJ Forum 3 10-13-2003 07:30 PM
wet legs locorojo Jeep CJ Forum 6 02-18-2003 10:17 AM
CJ Articulation How Do You Get It ?? harley Jeep CJ Forum 1 04-12-2002 08:31 PM
