Cranks but won't Fire - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Cranks but won't Fire
Income tax season is upon us. We got what u needGet 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerraGibson Exhaust Rebate - ExtremeTerrain!
Unread 03-15-2003, 11:13 PM   #1
MudLover
Well, we finally got some great weather here in Cincinnati, so I got the hard top off and went for a drive today. Everytime I would stop at a store or a friends house the engine had problems starting back up again. The starter would crank it's heart out, but it took an act of God to get it to actualy start. I found that if I popped the hood, pulled the oil dipstick, and then replaced it, the engine wouldn't crank AS LONG in order to start. What could cause this. Since it only happened when the Jeep had been driven for a while and the engine was warm, could the choke need to be adjusted? Any help would be great.
Thanks,
Marc
1979 CJ5 project
"Life is an issue of mind over matter. Ya see, I don't mind, and well...you don't matter."
[B][COLOR=darkred]Red Jeep Club Member #2[/COLOR][/B]
MudLover is offline   Reply With Quote Quick reply to this message
Unread 03-15-2003, 11:21 PM   #2
OldJeepguy
1979 CJ7
I had a similar problem on my 304 CJ - it turned out to be the ignition stator (AKA pickup, Hall effect sensor) inside the distributor - when it got hot it wouldn't restart. Like you, I found if I opened the hood it helped cool it down and it would start sooner.
The 258 uses the same sensor in the distributor - I found one at NAPA for $30, installed it and haven't had a problem in a couple years...
Steve
jeep79cj@yahoo.com
OldJeepguy is offline   Reply With Quote Quick reply to this message
Unread 03-16-2003, 02:30 AM   #3
scottahicks
this may sound stupid and way off base but heck you never know,,, did you check your pcv valve? sometimes when a pcv valve is not working properly it will build up pressure in the crankcase and cause all kinds of weirdness. the only reason I sight this is that you say you pulled the dipstick out which would vent the crank case and the cooler air would help the excess gases to cool down.. pcv valve is cheap, to test it pull it out and shake it,, if it rattles its good, just a thought, you never know
If its broke I can fix it. if it isnt broke give me a minute!!!
1980 CJ5, 304 V8, flat top pistons, rv cam, quadra-jet carb, edelbrock intake, hooker headers, Purple Hornies 3" header glasspacks, Solid Driveshaft, t-176 manual 4speed, 3" body lift, 1foot extended front bumper for wrecker winch "no winch yet" 33X12.5X15 Wild Country XRT's on chrome wagon wheels, custom spray paint job, lots of rust, dents, oh and a driver that treats it like a jeep "screw the paint I can make it!" Daily Driven!!!!! Green Jeep Club member #37 Flamed Jeep Club member #1 and President
scottahicks is offline   Reply With Quote Quick reply to this message
Unread 03-16-2003, 04:52 AM   #4
bernie
Here's another thought--
The wiring harness (with wires to the coil) generally runs near the dipstick. Per chance, when pulling the dipstick, you may have been bumping the harness and closing an open circuit--like a loose terminal, damaged wire, etc.; however, that probably would not have a relation to warming up.
And yes--the choke could need adjusted; that would explain it's co-relation to heat.
bernie is offline   Reply With Quote Quick reply to this message
Unread 03-16-2003, 10:13 PM   #5
cj5mudman4x4
I have had the same prob. with my jeep.. it turned out to be a bad coil. the coil would get hot and it would have to cool down.it could be your choke.. but if it just took a while to start and kept going when it started i wouldnt say it was the choke. caus it would "choke" itself out.
my .02
1973 CJ5
258ci I6 rebuilt. bored .40
Painless wiring harness
INDEPENDENT OFFROAD member Bowling Green, Ky
cj5mudman4x4 is offline   Reply With Quote Quick reply to this message
Unread 03-17-2003, 01:45 PM   #6
MudLover
I changed the oil today, and it helped. The old oil looked like it was crude...strait from the well. I still got weird looks from people when I would try to start it in parking lots, but oh well. I'll look into getting a new coil. Is that called a "Blaster Coil"?
Thanks for the help,
Marc
1979 CJ5 project
