cracked pumpkin - JeepForum.com
post #1 of 6 Old 09-19-2002, 04:22 PM Thread Starter
rustyCJ
cracked pumpkin
I have a crack in my axle pumpkin where the axle tube enters it on my front 30. the crack is on the top and I can tell that the weight of the jeep will slowly spread it open. the crack is on the short tube side and the spring U-bolt wraps over it. heres the question, can i weld the pumpkin/axle tube or when I'm driving down the road will the axle snap in two? Anyone done this to an axle before?
rustyCJ is offline
post #2 of 6 Old 09-19-2002, 09:56 PM
dana60cj
dana60cj's Avatar
No, I have not done this before first off.
Welds make the original metal stronger so they say. They must be the welders union.
If it is near that u-bolt who knows how far it goes into the pumpkin? A weld should hold for a while. If you do weld it make sure the areas that are cracked are flush. Just jack up the jeep by the pumpkin and the weight from the rest of the other end of the axle will make them flush.
Geeeeeesh did You do this? Time for a Dana 44 or a 60?
dana60cj is offline
post #3 of 6 Old 09-19-2002, 10:05 PM
only in a jeep cj
I'm sure someone will disagree with this, but if it were me, I would replace the housing as the Dana 30 is a common unit. I'm surprised it cracked on the short side as they are more common to crack on the long side. Yes, you could weld it, but what else is bent/damaged that caused the crack or is a result of the crack? If you have high miles on yours and find a good used one, swap it straight up if your gears match, OR rebuid it and have a solid axle when done.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 6 Old 09-19-2002, 10:22 PM
CSP
Welds don't necessarily make the original metal stronger. Usually the weld itself is stronger than the metal around it.
No matter what the case is there's no way I would try this. The problem is the pumpkin is cast iron. It is not steel and becomes very brittle when you weld it. Brittle means it will crack even worse than before the "repair". It's possible to weld cast, but there is a very precise procedure (preheating and slow cooling) that must be taken and the proper kind of rod must be used. Also, since the axle tube has already made the crack wider you no doubt already have a tube that's out of alignment. The tubes are a press fit into the center section and you'll never get the tight tolerances needed for seal life, gear wear, wheel alignment, etc..
Dana 30's are a dime a dozen if you look in the right places. You should be able to find one fairly cheaply from someone upgrading their old axles. An upgrade to a Dana 44 is an even better idea.
CSP is online now
post #5 of 6 Old 09-20-2002, 09:36 AM
4wheeler4CJ
4wheeler4CJ's Avatar
Thumbs up
If you have a Narrow Trac, I have 4 Dana 30 Front Axle Units for sale for $150/ea. Some have disc brake setups, some have the 11" drum setup.
Should you decide to replace it, you can email me at ericnmish@yahoo.com. All have 3.54 gears.
4wheeler4CJ is offline
post #6 of 6 Old 09-21-2002, 07:34 AM
werewolf7111
its best you DON'T attempt repair
CSP gave you some sound advice. I dont generally respond to posts but I have decades of designing machines and "upgrading" jeeps and I am going to tell you the caveats of what you may be thinking and as an engineer, why its not best you attempt it.
pumpkin- this is an investment casting( a coarse grain) which is NOT designed for axial load in an X and Y plane( up/down, back/forth)- due to the extremely low carbon content and high molecular clearance of a casting by design, if you apply heat, you will definitely alter the grain structure and cause further down range problems
shaft tube- this is cold rolled drawn tubing- the problem here is 2 different metals and a different coeffecient of thermal expansion- plus you "see" this crack but you DONT see the runners( only ultrasonic testing can find these) so you will just end up "moving" the "crack" ( in engineer speak- a "crack" is molecular in nature and has yet to break the surface- when it has, its referred to as a fissure)
alignment- assuming you wanted to proceed- you would need to have the unit cryogenically stress relieved- then jigged and lasered to find true alignment-then uniformly heated- then welded- then cryoed again- it aint worth it
werewolf7111 is offline
Has anyone ever cracked an AMC 20 Galt Jeep CJ Forum 8 02-10-2010 08:13 PM
Cracked Flywheel? thebeast77 Jeep CJ Forum 7 06-24-2006 08:39 PM
cracked head aesir Jeep CJ Forum 1 05-03-2006 10:39 AM
Oil Pan Cracked!!! longlimb Jeep CJ Forum 9 07-06-2005 10:05 PM
AMC20 Pumpkin - cleaning out old gear oil/sludge CJPoorhouse Jeep CJ Forum 9 08-02-2004 12:58 PM
