Cracked head and leaking radiator - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Cracked head and leaking radiator
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!The Ruffstuff NOT Universal 4 Link Kit!
Unread 01-25-2013, 09:51 PM   #1
Tacuff1414
So this is what I was told by my local mechanic was wrong with my CJ7.
I am new to anything to do with this, so is there any special way I need
to approach fixing this? How hard/expensive is a head to fix/rebuild?
Will the sealant you can buy to pour through the radiator be enough to fix
the leak? Any suggestions and on this would be helpful.
Tacuff1414 is offline   Reply With Quote Quick reply to this message
Unread 01-26-2013, 02:13 AM   #2
jayzcj5
1978 CJ5
Don't use that stuff, it is crap and is bad for everything else! Sorry to say but a cracked head means replace the head. Unless the crack is in a spot where you can weld it but even then its a shot in the dark. Luckily heads aren't too expensive out of a junkyard. There are many options but if you just want to replace what you have there are tons of write ups on here and google that could help you along. You should also buy a Haynes or Chiltons manual so you can learn as you go.
As for the radiator, there are repair shops just for them or scrap it and get a new one. Welcome to the jeep forum!
jayzcj5 is offline   Reply With Quote Quick reply to this message
