a couple other questions... - JeepForum.com
post #1 of 5 Old 08-29-2002, 05:57 AM Thread Starter
kasper37
in this pic:
http://www.fascistadmin.com/pieceofj...lutch_temp.jpg
does anyone have any idea what wire that is in the green circle? Also, how am I supposed to get the cap off of the hydraulic clutch cylinder (in the red circle)? I don't want to force it until I know if it screws off or just pops up.
I know these "mystery wire" questions are pretty vague but maybe someone might recognise where they are supposed to go:
http://www.fascistadmin.com/pieceofj...wire1_temp.jpg
(sorry for the blurriness of that pic) and finally this one:
http://www.fascistadmin.com/pieceofj...wire2_temp.jpg
thanks, Dan.
kasper37 is offline
post #2 of 5 Old 08-29-2002, 07:56 AM
kev1
I have the same set up. (I PM'd you.) I think the wire in the green cirlce, mine is disconnected too, goes to the light on the hood, I think.
The hydraulic resevoir cap does come off. It is in a bad spot, but I push down and unscrew. You don't turn it a full circle. It is similar to the radiator cap. You might not need to push down though. Non the less, it does unscrew off.
I will try to find the others in question. There should be a wire that goes to the carb. which controls fuel flow during idle.
Kevin
1980 CJ7 Rebuild:
Frame painted with a Rough Country 2.5" lift and shocks installed.
Alot of money spent on parts that are all over including a new 258.
kev1 is offline
post #3 of 5 Old 08-29-2002, 12:17 PM
CJ7Jeff
The wire in the last picture looks similar to the wire that plugs into the blower motor. Is this wire on the passenger side of the engine? If so that is my guess.
'85 CJ7 258 w/Weber Carb and Nutter Bypass. Dana 44's F&R, 3.73 gears with Trac-Loc rear. Always looking for peoples $0.02.
CJ7Jeff is offline
post #4 of 5 Old 08-29-2002, 12:48 PM Thread Starter
kasper37
carb wire...
there are two wires that are currently plugged into the carb. The one on top has two plugs and the one on the right (on the right when looking at it from the front of the car) is plugged into a little unit on the carb (sorry...I don't know what this "unit" is or I'd say). If the remaining wire is the one that regulates the idle it coule be the one causing my problems.
thanks again. Dan.
kasper37 is offline
post #5 of 5 Old 08-29-2002, 07:04 PM Thread Starter
kasper37
damn hydraulic clutch!
I still can't get that damn cap off of the hydraulic clutch cylinder. Time to start forcing things!
dan
kasper37 is offline
Couple more questions for the pre-start rundown, ignition, carb, misc questions..... Blthomas Jeep CJ Forum 3 07-01-2008 05:56 AM
Couple of CJ questions jasonneal Jeep CJ Forum 20 03-03-2007 07:57 PM
Couple Questions.. RN U OVR Jeep CJ Forum 1 08-14-2006 06:37 AM
couple of questions please YoungGunz Jeep CJ Forum 7 01-31-2005 06:39 PM
Couple of questions paypwip Jeep CJ Forum 6 01-19-2003 10:17 AM
