Couple o' CJ - YJ interchangeability questions... - JeepForum.com
post #1 of 13 Old 01-03-2012, 06:07 PM Thread Starter
shum8
1980 CJ7
Noob here again.......Sorta Noob, anyways - The previous CJ's I've owned were all CJ since at that time, that's all there was.
I recently bought a CJ/YJ hybrid as an alrready started project to finish. PO put a YJ tub on an 80 CJ and I figured it must have been an easy swap. In digging around, I've found a few things that beg a question or two.
First, there is no backup light harness. I'm getting ready to order the first batch of stuff, this harness being in the batch. My question is, where does it plug in the the main harness? I know it attaches to the switch on the trans, but it T's from there, and I don't see any empty connectors fpr it to plug into.
Second question - Any easy way to tell whether I have a CJ or YJ heater box? There seems to be a sizeable blast of cold air coming in at the passenger floorboard, so my assumtion is he kept the CJ heater box and stuck it in the YJ tub best he could, and it's not fitting as well as it should.
All my previous CJ's never needed any extensive work - this one is going to be a whole nuther deal. I'm looking forward to fixing this one up - it has several small issues, then it just needs paint. I'm hoping to get it done before you folks get tired of me asking stoopid questions
Shum8
shum8 is offline
post #2 of 13 Old 01-03-2012, 06:13 PM
Ollie09
1983 CJ7
This thread shows a picture of both.
Gary
http://www.jeepforum.com/forum/f8/he...boxes-1306816/
Ollie09 is offline
post #3 of 13 Old 01-03-2012, 06:23 PM
only in a jeep cj
You need to determine if you have a CJ or YJ harness. Im assuming they used the CJ dash. One the engine side of the firewall between the battery and engine, the harness should have a small section with I believe 3 or 4 wires coming out to a flat black plastic plug. This is where the transmission wires hook up for the reverse lights and 4 wheel drive light. .I read yours is missing? There are two common types. One for the T-176 type which is a two blade flate prong and the SR4 T4 T5 type is two round studs.
Are your dash cables hooked up? I ask as they don't really work with the YJ box. An easy way to tell is the brackets for the YJ box will have small square holes where the cables snap in. The CJ type will have a shape of "U" on the brackets before the levers. Also the YJ have a vac operated cowl vent door. CJs are cable.
Maybe some pics will help us see any other "issues"
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is offline
post #4 of 13 Old 01-04-2012, 11:59 AM Thread Starter
shum8
1980 CJ7
Yep - CJ dash
One the engine side of the firewall between the battery and engine, the harness should have a small section with I believe 3 or 4 wires coming out to a flat black plastic plug. This is where the transmission wires hook up for the reverse lights and 4 wheel drive light. I read yours is missing?
There is no plug on the transmission switch - hence no back up lights. Funny thing is the 4 wheel drive light works off and on. I've looked around underneath, and don't see any sign of the harness for the backup lights.
Yes, sorta. The vent cable doesn't do anything, and the temp cable doesn't seem to alter the temp. Floor / defrost cable works. I just need to pull the dash and see what the heck's going once warm weather gets here.
Right you are - Pics are much better. I'll take a few and post 'em.
Thanks for the info - I appreciate the help.
Shum8
shum8 is offline
post #5 of 13 Old 01-04-2012, 04:44 PM Thread Starter
shum8
1980 CJ7
Ok - I took a few pics when I got home. They are of a connector that is part of a small loom that enters from the rear of the fuse block. This is the one that matches the description of the T176 transmission connector. I assume I am missing the whole backup light harness? Wonder why the 4WD light will light occasionaly? Guess I shout name this one "Christine".........
Thanks in advance for the help - I really appreciate it.
Shum8
shum8 is offline
post #6 of 13 Old 01-04-2012, 05:07 PM
only in a jeep cj
No that is for the brake light via the proportioning valve down by the clutch linkage. Go to the other side of the engine and as the harness crosses over the valve cover area, there is a four wire flat black plug. The fact your 4 wheel drive light comes on at all tell me you have the harness plugged in. Follow this harness under the right side of the trans tunnel and you should find it forks. One side goes to the t case, and the other has the trans reverse plug. Propoly not plugged in and dangling somewhere just out of sight.
Ed
1975 CJ-6 1983 CJ-8
post #7 of 13 Old 01-04-2012, 06:06 PM
lucdog
lucdog's Avatar
1980 CJ5
I believe he's talking about this one.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 13 Old 01-04-2012, 06:10 PM Thread Starter
shum8
1980 CJ7
Well, we're making progress. This one was on the other side - empty.
I agree that the fact the 4WD light comes on at all meens something is connected. I'll crawl under it tomorrow and see if I can find the other end of the harness.
shum8 is offline
post #9 of 13 Old 01-04-2012, 06:18 PM Thread Starter
shum8
1980 CJ7
Bill -
That looks remarkably like the one I found empty....... So much for progress - LOL. I'm trying to get in touch with the PO to see exactly what harness is in the Jeep. I can't wait to see why the 4WD light will occasionaly come on if the harness isn't there.
That does it - "Christine" it is.
Robert
shum8 is offline
post #10 of 13 Old 01-04-2012, 06:52 PM
lucdog
lucdog's Avatar
1980 CJ5
Sorry if I missed it, I looked twice. I looks like you have a SBC, and a automatic, what transmission and transfer case? why not take a few and fill out your profile.
On edit, when you say the 4wd light come on sometimes, even when its not in 4wd? IIRC the transfer case switch turns on the ground for the light, in the dash. It may be getting a ground from a bare wire.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #11 of 13 Old 01-04-2012, 07:12 PM Thread Starter
shum8
1980 CJ7
Sorry bout that - just updated. This one has an AMC304, T176 and Dana 300.
shum8 is offline
post #12 of 13 Old 01-04-2012, 07:15 PM Thread Starter
shum8
1980 CJ7
Bill
Well, that explains that - yeah, it was on yesterday for a short period of time, no mater the position of the TC stick. Figures it colder than a welldiggers arse here now - soon as it gets a bit warmer, I'm diggin in again.
shum8 is offline
post #13 of 13 Old 01-08-2012, 12:32 AM Thread Starter
shum8
1980 CJ7
Well, spoke to the PO about the back up lights - when he said all that needed to be done was to "just hook 'em up". he left out the part about the whole dang backup light harness wasn't there...... Was hopin I'd get to buy a new one
shum8 is offline
a couple questions about the cj5 NExOBLIVISCARIS Jeep CJ Forum 9 09-17-2011 10:30 AM
couple questions... puppy-v8 Jeep CJ Forum 0 11-04-2010 10:05 AM
Couple more questions for the pre-start rundown, ignition, carb, misc questions..... Blthomas Jeep CJ Forum 3 07-01-2008 06:56 AM
Hello, a couple questions. Tangible Demise Jeep CJ Forum 9 05-16-2006 07:55 AM
a couple other questions... kasper37 Jeep CJ Forum 4 08-29-2002 08:04 PM
