Correct way to set up fuel filter - JeepForum.com
post #1 of 17 Old 06-12-2011, 02:11 AM Thread Starter
monomoy4
1979 CJ7
I'm about to replace the fuel filter on my '79 CJ7. Am I correct in thinking that whoever set it up before did it incorrectly? the filter to vapor canister outlet is below the filter to carb. from what I've read on this forum, the vapor tube should be at the top with cab outlet at the bottom. could this set up lead to the gas smell I have in the garage??
monomoy4 is offline
post #2 of 17 Old 06-12-2011, 02:11 AM Thread Starter
monomoy4
1979 CJ7
there's supposed to be a pic...hold on...
monomoy4 is offline
post #3 of 17 Old 06-12-2011, 02:12 AM Thread Starter
monomoy4
1979 CJ7
monomoy4 is offline
post #4 of 17 Old 06-12-2011, 02:50 AM
BagusJeep
1981 CJ7
And lo and behold the picture has it incorrectly mounted, sod's law. It is almost there but not quite correct.
If this is the fuel filter next to the carburettor you are enquiring about there are a number of Tubes (metal fuel pipes in Jeep speak) and the only Hoses are short sections next to the filter. These are a service item that should come with a new filter and be changed at the same time. If you have long lengths of Hose consider buying some Tube, it will reduce fire risk.
The filter is mounted horizontally, very important, and the outlet to the carburettor is at 6 o'clock. At 12 o'clock is the fuel return pipe to the tank. There is no bracket, the Tubes hold it in the right attitude.
The filter carb outlet should be at the same level or slightly above the carb inlet.
If all the above is done the carb will be supplied with a constant low pressure fuel supply with good quantity available.
BagusJeep is offline
post #5 of 17 Old 06-12-2011, 07:31 AM
Mike Romain
Yup, as mentioned, it is upside down. Usually you can just give them a good twist. 'All' the filters I have bought for mine come with 3 new pieces of hose to connect up the new filter with so those are supposed to get changed every filter for safety reasons. Old lines dry out.
Mike
Mike Romain is offline
post #6 of 17 Old 06-12-2011, 12:05 PM Thread Starter
monomoy4
1979 CJ7
Thanks All - I've got a new filter kit with 3 sections of hose ready to go. I will install as you've directed. Is there anything special I should be doing prior to removing the old filter?? I've read there's some pressure in the fuel line...I don't want gas spraying everywhere... This is the first fuel filter I've replaced on a car.
monomoy4 is offline
post #7 of 17 Old 06-12-2011, 05:13 PM
wellmax
most times the gas pressure bleeds off if you let the engine cool. You do not want to spray gas over a hot engine anyway.
I run the top hose out on the filter to the cansiter and bottom out hose to carb.
works fine.
my little 4 banger (1984) fires right up and run full blast with all of its 60+ hp, real highway burner. But plenty of power for me.
wellmax is offline
post #8 of 17 Old 06-13-2011, 08:54 AM
Mike Romain
You can have a catch tray of some kind under the carb to catch the gas that will leak out. I use the bottoms of antifreeze or WW fluid containers for catchers of stuff and as cleaning trays. Usually I just cut the side out so it still has the spout to pour of the fluid later.
Be aware that the hoses are different sizes, the smaller piece goes on the 'return line' nipple up top. Same for the clamps, 2 will be different colours that the other 4 usually. Personally I prefer to use worm gear clamps that you tighten with a screwdriver over those squeeze clips. I have had too many clips fail over the years.
Mike
post #9 of 17 Old 06-13-2011, 05:59 PM
LimeLite
1978 CJ5
i've seen a couple references to one of the lines on the filter going to the vapor canister, I was under the impression it ran back to the tank
78 cj-5 4" procrap lift on 35's amc304 "custom" rear bumper/tire carrier combo, rollcage...
Ex-Member of offroad nuts
LimeLite is offline
post #10 of 17 Old 06-13-2011, 06:04 PM Thread Starter
monomoy4
1979 CJ7
Great advice - thanks again
monomoy4 is offline
post #11 of 17 Old 08-16-2011, 10:02 AM
drive78CJ7
1978 CJ7
Sorry to bring an old post up but I am having some trouble with my fuel filter.. I took of the old one not looking to how the lines connected.. not I cannot get fuel to the carb.. I think i have the lines mixed up.. On the side of the filter with the two outlets does the outlet in the center of the filter go to the canister? wile the one at "6 oclock" or the outlet on the edge of the filter go to the carb? right now I have it the other way and it doesnt seem to work. before I switch it again I figured id ask you guys.
photos of the correct set up would be great.
Thank you
drive78CJ7 is offline
post #12 of 17 Old 08-16-2011, 10:16 AM
swatson454
1983 CJ7
Here you go. The center-out goes to the carb and the smaller, bypass outlet goes back to the tank.
I hope it helps.
Shawn
Live in a way that those who know you but don't know God will come to know God because they know you.
swatson454 is offline
post #13 of 17 Old 08-16-2011, 10:45 AM
drive78CJ7
1978 CJ7
Ok that helps alot thank you.
post #14 of 17 Old 08-16-2011, 01:29 PM
wellmax
on end of filter with one opening, that is the inlet.
on the other end with two outlets.
center one is to carb.
one on outside goes to canister and it should be placed up above the one going to carb.
some have had problems with fuel draining back from carb to cannister. so canister outlet must be above outlet to carb.
wellmax is offline
post #15 of 17 Old 08-16-2011, 01:40 PM
mcmud
1983 CJ8
The return tube is not intended to be connected to the canister, its routing is to the fuel tank.
mcmud is offline
cj7 , fuel filter , installation
Fuel Filter (which way)? ralin Jeep CJ Forum 4 04-27-2011 09:32 PM
Charcoal Canister, fuel tank vent, and fuel filter vent help guitarfreak6688 Jeep CJ Forum 10 03-22-2011 07:12 AM
Fuel filter/vapor-lock/fuel starvation...help please. hh65flyer Jeep CJ Forum 1 07-22-2009 04:05 PM
new 12v fuel gauge wont read correct and vent hose check valve camodad Jeep CJ Forum 7 03-24-2009 07:46 AM
Fuel filter tmoreau Jeep CJ Forum 1 04-11-2007 04:31 PM
