Correct way to assemble factory draw bar / trailer hitch with bumperettes? - JeepForum.com
post #1 of 5 Old 07-01-2013, 02:38 PM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Does anyone have and photos showing the correct way to install the factory draw bar / trailer hitch with the factory bumperettes? I can't find a photo or diagram that clearly shows how it's all supposed to fit together. I'm hoping to buy bolts so I can install the draw bar but until I know how it all goes together, I don't know what length bolts to get.
Thanks!
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #2 of 5 Old 07-01-2013, 05:03 PM
hp_lovecraft
1981 CJ5
The way mine was setup was the trailer hitch mounted between the bumperettes and the frame, though I replaced the bumperettes long ago.
hp_lovecraft is offline
post #3 of 5 Old 11-22-2016, 09:03 AM
bri72cj5
1972 CJ5
See attached picture from 1973 service manual. This is how it is installed my 1972 CJ5.
bri72cj5 is offline
post #4 of 5 Old 11-22-2016, 09:19 AM
keith460
Jeep. There's Only One
keith460's Avatar
Here's an archived photo I have. Bumperette is attached over the mounting tab of the Draw bar
1984 CJ-7 Renegade
keith460 is offline
post #5 of 5 Old 11-22-2016, 10:44 AM
JeepdaddyRC
1983 CJ5
Here is a diagram of the later model factory draw bar. The factory draw bar rear crossmember bracket (#9) is mounted under the bumberettes and a spacer is used on the outboard side to adjust for the draw bar thickness. Be sure to include the frame tie-ins (#21) and anti-crush sleeves (#23) if you tow anything with it. Many CL and ebay sellers do not include those essential components.
JeepdaddyRC is offline
