Correct type of fluid for AMC 20 differential? - JeepForum.com
post #1 of 23 Old 01-22-2011, 08:37 AM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
What is the correct type of fluid for the AMC 20 differential? And does anyone have any specific part numbers?
Jeephammer reccomends "80-85 gear oil" fluid in this post. Another person reccomends "AMSOIL Severe Gear 75W-90AMSOIL" in this post. This post also reccomends about half a dozen other general types.
I would tend to trust Jeephammer's reccomendation, but where can I get 80-85 gear oil? A search of the Napa website is of no help, so I'm turning to you guys. I see threads often here of people rebuilding axles, so certainly someone has some part numbers handy! I'm sure this will turn out like those posts of people asking what fluid to use in the T5
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #2 of 23 Old 01-22-2011, 08:54 AM
brownbagg
1930 MK Compass
any walmart will have it, any 90 wt will work. its nothing special
brownbagg is offline
post #3 of 23 Old 01-22-2011, 09:01 AM
texasimport
1978 CJ5
After fixing the drivers side bearings and putting in Mosers, I did the AMSOIL in mine, so far so good.
78 304-CJ5
texasimport is offline
post #4 of 23 Old 01-22-2011, 09:06 AM
skidplate77
1977 CJ7
80W-90 I think would be fine...
1977 Jeep CJ7 Renegade, 304 V8, Torque Flite 999 automatic, Dana 300, AMC 20, Dana 30 front, 30" X 9.50" tires, building it back to stock..
A new work in progress, and a new lease on life...
skidplate77 is offline
post #5 of 23 Old 01-22-2011, 09:12 AM
benullman
1981 CJ7
yep! Just plan ol' gear oil. I used GL5 in mine. 75W-90
Ben
Originally Posted by Gregg79CJ7304 View Post
Great minds think alike, but so do serial killers......Thanks.
benullman is offline
post #6 of 23 Old 01-22-2011, 09:47 AM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Okay, I looked in the 84-86 Factory Service Manual and it states:
"SAE 75W-90 API Grade GL-5 quality...
2.25 liters (4.75 pints)"
So can anyone provide a part number from a specific manufacturer?
Ken4444 is offline
post #7 of 23 Old 01-22-2011, 12:21 PM
Full Tank
1980 CJ5
Ken, you really can't go wrong with any of the big name oil/lubrication companies for a conventional (non-synth) GL5.
My Dana 300 just loves Valvoline.
FT
1980 CJ5 39k
Dana 30--AMC20--D300--T176--258
Dana 30--AMC20--D300--T5--2.5L
Full Tank is offline
post #8 of 23 Old 01-22-2011, 03:55 PM
brownbagg
1930 MK Compass
it just plain 90 wt, any walmart, auto zone, advance has it
post #9 of 23 Old 01-23-2011, 06:59 AM
rustedcustom
1983 CJ7
Spend the coin and go full synthetic. Far better rolling resistance, lower operating temps, thicker dynamic wear cushion. Chevron Delo Synthetic 75/90 . . . $140 retail for 35lbs (5 gals) I would change out your Dana 30 also. And did I mention . . 500,000 mile recommended drain interval ? I believe Shell and Mobil sell it by the qt / gal where as Chevron/Texaco does not. Any heavy duty truck parks store should have it or I know the trucks stops like Petro , Pilot , or Flying J shelf it but you would pay an inflated price there. I pull my Chevron product out of Port Artur and know many distributors in the Houston area.
America Reborn November 6, 2012
My Baby is a cold blooded b****
Carter BBD ( The 8th Wonder of the World )
rustedcustom is offline
post #10 of 23 Old 01-23-2011, 07:20 AM
halpeters
1978 CJ7
For the AMC-20 the important thing is using a "GL-5" 75+/- to 90+/-W oil. The GL-5 classification means the oils has the correct Extreme Pressure" (EP) lubricants for the ring and pinion gears.
Choose your favorite flavor of oil, and change it regularly- 10,000 miles or less, or after any "under water events". The reason we change the gear oil is to remove accumulated dirt and water.
If you have a "track-lock" clutch type posi differential, be SURE to use the "track-lock" additive in the oil...
IGNORE any discussion of "extended drain intervials", "Synthetics are good for 500,000 miles", etc. Any gear oil that you use will last forever. The problem and the reason for short change intervials is the oil gets dirt and water in it, from the way most Jeeps are driven. Remember, the AMC-20 has an unfiltered vent line that allows air (with dirt and moisture) to move in and out of the differential.
Oh, don't use the GL-5 gear oil in your transmission....
1978 CJ-7
Last edited by halpeters; 01-23-2011 at 07:29 AM. Reason: added comment about additive in the oil
halpeters is offline
post #11 of 23 Old 01-23-2011, 07:24 AM
Skerr
Nothing wrong with synthetic. You either live by it or you don't. It's good stuff, but unnecessary. No insult intended. Standard gear oil is more than satisfactory.
FT
Agree...
Pretty much what FT says... Any of your parts stores will have it, WM, etc.
Kerrdog
Go Fish! <*////><
Skerr is offline
post #12 of 23 Old 01-23-2011, 07:50 AM Thread Starter
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Thanks to everyone for the input. The information was helpful. Diff fluid seems to be much more common than gear oil for my T-5. Here are some photos and commentary of the fluid fill job if anyone is intersted.
Ken4444 is offline
post #13 of 23 Old 01-23-2011, 08:16 AM
eumel789
2009 JK Wrangler
That pic saus it all, thank you
eumel789 is offline
post #14 of 23 Old 01-24-2011, 04:24 AM
rustedcustom
1983 CJ7
Please don't IGNORE the fact that the lubricant recommendations for your jeep is based on almost 30 yr. old technology. Will any XYZ gear lube work?
Of course. Do you want to minimize wear in your gear boxes and motor? Then don't IGNORE the advances that petroleum engineers have made in the past three decades.
post #15 of 23 Old 01-24-2011, 06:47 AM
82JeepCJ7
1982 CJ7
I used just plane ole 90wt. The cover was so shot from being dragged over rocks that it would need to be refilled every two weeks or so. It was like a constant lube change, so I was not going to use anything expensive. Never had an issue running 90wt and neither will you, despite what the amsoil dealer wants you to think (cha-ching)
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
whats the correct tranny fluid? flybo Jeep CJ Forum 5 04-29-2009 06:48 PM
Locking type differential onesourcemike Jeep CJ Forum 20 08-06-2008 09:15 PM
Some Type of Fluid Leak Drsafety Jeep CJ Forum 6 06-10-2008 01:43 PM
Correct Fluid and amount for T-18 4-speed? JeepinYahoo Jeep CJ Forum 3 03-28-2007 11:07 AM
T-5 Transmission - Not about fluid type... MuddyMules Jeep CJ Forum 7 01-11-2007 03:08 PM
