correct angle of driveshafts - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > correct angle of driveshafts
WJ Tube Doors Now Available!*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*TJ 5.25" Speaker Adapters - NalinMFG
Unread 05-19-2014, 08:02 AM   #1
coyboy2
does anyone know how much angle is too much, i put a 4 inch rough country lift on which came with a transfer case drop kit but i am still concerned about the angle and am wondering if i need to shim......Thanks
coyboy2 is offline   Reply With Quote
Unread 05-19-2014, 08:15 AM   #2
CSP
Do you have any driveshaft vibrations? If not, you don't need to do anything.
CSP is offline   Reply With Quote
Unread 05-19-2014, 11:21 AM   #3
Renegade82
Renegade82's Avatar
1982 CJ7
It's more important to get the 2 end angles close to matching (yokes to shaft) than it is the overall angle to the ground..... to a point, then it's just bad for the shaft period. IMO
The end of a defining era.... JEEP R.I.P. 1941-1986
My frame off Re-Build: (still in progress....)
http://www.jeepforum.com/forum/f8/30...e-off-1280850/
Renegade82 is offline   Reply With Quote
Unread 05-19-2014, 12:46 PM   #4
coyboy2
Thanks for the info
Unread 05-19-2014, 01:45 PM   #5
Manhattan
Manhattan's Avatar
1981 CJ8
I've never dropped a t-case to accommodate a lift (dropped one a buddy's elbow... but I digress) - CJ5, CJ7 or CJ8. Renegade82 nailed it - match the angles of the t-case output shaft and the pinion shafts, and you should be golden.
1981 CJ8, Chevy 5.7, SM465, D300, RE 4.5, 35" BFG MTs, 20/30 4.56, Detroits, Warn 9500ti
Manhattan is offline   Reply With Quote
Unread 05-19-2014, 08:41 PM   #6
rjf1978
I just went through the same thing. I ended up swapping the shaft for a CV shaft (no t-case drop) with 10 degree shims. All is well now.
rjf1978 is offline   Reply With Quote
