corporate 10 bolts - JeepForum.com
post #1 of 5 Old 11-03-2006, 05:38 PM Thread Starter
dave_dj1
corporate 10 bolts
any good or bad experiences with these axles? i have a chance to pick up a set for cheap.
dave_dj1 is offline
post #2 of 5 Old 11-03-2006, 05:56 PM
jeepskate
Generally not very highly regarded, about on par with Dana 44's at their best parts. Poke around Fourwheeler.com's site...they have an axle guide that gives the good, bad, ugly, limits, etc on most axles.
'86 CJ-7 Laredo: 4.2,T-999,D300,D30/D44,'94 YJ tub, full cage, Shrockworks rockers, OYR corners, AC,cruise,restored seats,3 tops,2.5" Superlift,F-T shackle reversal, RS9000x's,35" Dunlop Mud Rovers.
'83 Scrambler: time & money pit under construction with parts from CJ's,YJ's,TJ's,FSJ's,GM,Ford,IH,Honda,Toyota and a whole lotta aftermarket & custom stuff.
jeepskate is offline
post #3 of 5 Old 11-03-2006, 10:28 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Front axle uses the same outer stuff as a D44 not bad for a front application. I think Shannon Campbell used one on one of his first buggies. Rear 10 bolt uses a C-clip... 8.5" ring gear and I think 30 spline axles. Probably good up to about 35ish size tires and moderate wheeling.
BESRK is offline
post #4 of 5 Old 11-03-2006, 11:10 PM
Pacfanweb
Go Wolfpack
Pacfanweb's Avatar
1981 CJ7
I know I had one in my 76 Trans Am, which had a 400hp engine.
I drag raced the hell out of it using slicks. Never had a rear end problem.
Tore up plenty of other stuff, though.
Pacfanweb is offline
post #5 of 5 Old 11-03-2006, 11:43 PM
Crash'emup
1976 CJ7
I was told today. To use one up front and then take the posi. guts out of an older ta or camaro and use them in the carrier.
Crash'emup is offline
How do I fit a corporate ten in the front of my CJ-7? jfrdog Jeep CJ Forum 5 11-19-2008 06:44 PM
Corporate 10 bolts greaseboysjeeps Jeep CJ Forum 7 02-26-2008 07:36 PM
AMC Corporate 20 Rear Axle Hub turbogus Jeep CJ Forum 6 06-11-2005 07:31 PM
GM corporate axles Ezredcj Jeep CJ Forum 4 02-17-2005 09:47 AM
broken rear spring hanger bolts cj5. got the broken bolts out now what? COBRA5LADDICT Jeep CJ Forum 6 11-12-2004 06:55 PM
