now what exactly is 'heavy duty' about it? Because I have the offset cap. Everyone else around here with a CJ has the central. Are we talking a 4 vs.3 core radiator? or what?
I know on mine and I have 3 the cap is off set. and the tanks are squared edges. 1 is the oem and one has been re-cored from a 2 core to a 3 core and one is a new replacement. I have an early 7 with a 304 that is being parted out and the rad on it had a center cap and the tank was rounded, don't remember how thick the core was. But there could be some difference whether it is a an east coast jeep or a Ca. Mine are all ca. jeeps. That's all the confusion that I can add.
When you do some checking you will find that the standard radiator has a 2 tube 1 1/2" thick core 15 7/8" between the tanks. A heavy duty has 3 tube 2" thick core 15 5/8" between the tanks. There's also a 2 core that that has a 16 3/4 "between the tanks. But remember we are dealing with vehicles that are at the very least 25 years old and things could have been changed. When you say is that the only difference What else would there be? There are only the Rad, w/p therm, water and the hoses that make up the cooling system. A high flow after market water pump could be added but the flow is controlled buy the thermostat. Remove the thermostat and the water will go through the radiator so fast that it will not cool in hot conditions, and the engine will not warm up cold conditions.
I believe the FSM shows the heavy duty cooling as a 2 core radiator with the sharod and a cluth fan. the standard as a 3core with out sharod and standard fan on the 4.2
Here's the Cooling Chart from my FSM...hope it helps to clarify some questions for everyone. Keep in mind this is for 1976, so other years may have varying options on them...the Tempatrol is the fan clutch, btw.
'82 FSM covers the '83 year sorry for the pic, scanner is mad at the laptop
Related Threads
Jeep Enthusiast Forums
18.5M posts
727.5K members
Since 2000
