Coolant gushing from radiator - JeepForum.com
post #1 of 3 Old 03-30-2010, 12:04 AM Thread Starter
teufelhundren
I just replaced the thermostat on 1985 CJ7 4.2. after installing and replacing coolant, I started her up and left the cap off to monitor the coolant level. About 10 minutes later coolant began gushing out of radiator. Is this a pressure issue because the cap was off, or is this a blown head gasket. Any insight would help.
teufelhundren is offline
post #2 of 3 Old 03-30-2010, 12:16 AM
Drednot
That happens from time to time.
Probably the air trapped in the head burped out when the thermostat opened.
Let it cool and refill. Look up the cooling system capacity and see if thats how much you put in.
If you have close to the right amount, close it up and fill the overflow bottle to the line and it should top itself off after a few hot-cold cycles.
Drednot is offline
post #3 of 3 Old 03-30-2010, 12:22 AM Thread Starter
teufelhundren
cool, Thanks....I pray to god that its not the engine. Im going to try the ride tomorrow, and see how she runs.
Started without coolant, now coolant in oil. Blown head gasket? bkkrehbiel Jeep CJ Forum 6 12-26-2009 07:22 AM
Still over heating: no coolant flow, boiling coolant CJATE Jeep CJ Forum 45 07-15-2009 04:24 PM
Do I need a Chevy Radiator or a Jeep Radiator? brice1310 Jeep CJ Forum 8 04-19-2007 07:46 PM
Take coolant temp reading before or after radiator? fromme Jeep CJ Forum 3 09-27-2005 02:10 PM
Water gushing from the Headlights ????? MangesMade Jeep CJ Forum 0 09-09-2003 12:49 PM
