Coolant Draining Troubles - JeepForum.com
post #1 of 10 Old 01-21-2013, 08:07 PM Thread Starter
marksud
I'm currently underway with removing the head to replace some freeze plugs and the head gasket. I drained the coolant through the radiator however, I'm not sure if there is a drain plug on the block. After draining the radiator I did notice some coolant remaining in the intake manifold and the hose. It's a 85 with a 258 inline 6 (just for reference).
marksud is offline
post #2 of 10 Old 01-21-2013, 08:23 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Driver's side of the block, below the 2nd & 4th freeze plugs.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
post #3 of 10 Old 01-21-2013, 09:23 PM Thread Starter
marksud
Thanks.
marksud is offline
post #4 of 10 Old 01-21-2013, 09:29 PM Thread Starter
marksud
Max... upon closer inspection I don't have that many freeze plugs on my drivers side. I'll post a picture tomorrow morning for you all to look at.
marksud is offline
post #5 of 10 Old 01-21-2013, 10:14 PM
Mean Max
Don't poke the bear
Mean Max's Avatar
Quite possible. The pic I used is just one I found quickly online to use for reference. But you should still have at least one threaded bung on the driver's side.
I have several 258 equipped CJs at my shop, and a 1984 model 258 on the floor. I'll verify the exact location in the morning.
Max
Mean Max is offline
post #6 of 10 Old 01-22-2013, 08:32 AM Thread Starter
marksud
Thanks! Appreciate your time to help!
marksud is offline
post #7 of 10 Old 01-22-2013, 08:57 AM
82JeepCJ7
1982 CJ7
I know this is on an AMC V8, but the same can be used on an inline 6.
Remove the radiator cap. After draining all the coolant out, install a airline quick disconnect male into the threads of the block. Hook up some regulated air, not to exceed 10psi. That air will force out any fluid that is still in the block to the radiator.
When I did my block, I made a device to inject air and water to flush the block. I used higher psi, but I didn't have any hoses, etc hooked to it. You would be amazed at what comes out....
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #8 of 10 Old 01-22-2013, 12:23 PM
248107
1983 CJ7
damn 82 that'll make the grass grow
248107 is offline
post #9 of 10 Old 01-23-2013, 06:47 AM Thread Starter
marksud
Wow! Didn't see that coming out of the block. Another question. Is it necessary to drain all the coolant in the entire engine just to remove the head? Or will draining everything that is currently in the radiator enough? I've heard it both ways.
marksud is offline
post #10 of 10 Old 01-23-2013, 06:49 AM Thread Starter
marksud
I should also point out that the only plug I'm replacing is the one on the rear of the head (culprit to the the green puddles I seem to leave everywhere...)
marksud is offline
coolant , head , head gasket , radiator drain
