Cool it down!!! (Contour Fans) - Page 2 - JeepForum.com
post #16 of 23 Old 05-16-2013, 06:40 PM
BleepinJeep
1988 XJ Cherokee
Originally Posted by Outnumbered View Post
Just ground (-) to the temp sensor switch instead of the chassis. It will create a ground at about 208* and complete the circuit. I'm not familiar with XJ relays so I cannot say what is going on with them but I'm fairly certain there is a computer control aspect to the XJ that the CJ did not have.
Good luck
Well there is no place to ground to. But even so, the switch is not completing a circuit even at 212 when I test it in the kitchen. With only one wire coming off this switch I am confused how you hooked it up to the relay?
Website -
- The Best Offroad Videos of Youtube with None of the Boring Stuff!
You Tube -
- Awesome Jeep Related How-To Videos in HD.
A wise man once told me, "I am going to give you some advice; you can take it or leave it, but keep in mind that it is worth exactly what you paid for it"
BleepinJeep is offline
post #17 of 23 Old 05-16-2013, 06:50 PM
titomars
1981 CJ7
one wire fan switch's are the ground. Your relay is energized by the ignition switch or how ever you decide to supply power to it. The opposite side runs from relay to switch, the switch heats up to the rated temp and closes itself internally to ground through the head/block. Which completes the circuit inside the relay to energize the the load side of the relay (the fan wire/s) which turns the fan on.
When cool enough the switch opens breaking connection and the ground to the relay, effectively shutting off the fans.
To bench test a fan switch in water you use an ohm meter one lead attached to the shell of the switch the other lead to the terminal. closed 0.00, open infinite
1981 Jeep CJ7 4.0 HO, AX-15, D300, D30, D44, SOA
1977 Chevrolet C/10 step side 454 TH400 3.73 posi
titomars is offline
post #18 of 23 Old 05-16-2013, 07:03 PM
BleepinJeep
1988 XJ Cherokee
Ok, thanks. That is exactly how it is set up I was just using the wrong term for ground. But the bench test failed, the brand new switch is not closing the circuit. Any ideas?
Website -
You Tube -
post #19 of 23 Old 05-16-2013, 07:47 PM
titomars
1981 CJ7
No real ideas except the switch may be bad or it just turns on higher than 212f
I originally bought a switch like that Murray one. The application was for a GM car but it did not turn on till 220f+ even though it was rated for 205f the weirdest part was it would not shut off till the temp dropped well below t/stat closing temp. I ended up going with a different brand entirely. I used a universal switch from Summit rated 200f on and 185f off. that one worked perfectly for me running a 180f t/stat.
http://www.summitracing.com/parts/sum-890018
titomars is offline
post #20 of 23 Old 05-17-2013, 09:45 PM
BleepinJeep
1988 XJ Cherokee
Ok so I figured out what is going on but I'm still confused as how to proceed. The factory leads coming out of the wire loom and going to the factory fan switch (which was in the radiator) is positive. So when I picked up a single pole switch that shorts to ground and installed it into the thermostat housing, I assumed the stock leads were negative. It wouldn't be a problem with a switch with two wires coming out of it but with only one wire I have to short to ground, not connect to positive wires.... Is this making any sense? It's hard to explain but now I'm at a loss.
If I could isolate the switch it wouldn't be a problem but obviously the switch is connected to the thermostat housing which is grounded to the engine.
Website -
You Tube -
post #21 of 23 Old 05-17-2013, 10:23 PM
CJ7KAHUNA
Here is what I ended up going with. When I get my Jeep back and get it installed I will finally get to test it.
CJ7KAHUNA is offline
post #22 of 23 Old 05-18-2013, 11:45 AM
titomars
1981 CJ7
I wired my fans up single speed. Using 2 relays and 2 circuit breakers, one for each fan both sharing the single sensor. So i am not sure how you are trying to get yours to work but here is a simple relay wiring diagram.
The switch between the ignition switch and terminal 86 is optional. It is for killing the fans during deep water crossings. On would be normal operation and off would shut down the fans manually.
titomars is offline
post #23 of 23 Old 05-18-2013, 09:29 PM
BleepinJeep
1988 XJ Cherokee
Thanks guys! What I was trying to do was wire the new switch to the factory relay without adding anything new... And I finally figured it out and got it working by finding the ground wire which was hiding in a huge bundle of factory wires. So I got that working but now my my jeep wont even turn over, I must have shorted something while testing all the wires... Dammit.
Website -
You Tube -
contour fan writeup? RockScar Jeep CJ Forum 11 08-24-2012 08:47 AM
Ford Contour Fans, Controler Question? Paperboy326 Jeep CJ Forum 16 08-08-2012 09:35 AM
Contour Fan won't fit??? johnson30 Jeep CJ Forum 8 02-09-2012 05:33 PM
Contour fan... something to be said for dual fans. VACJ7 Jeep CJ Forum 18 08-09-2011 02:20 PM
Contour Fan Set-up StewartCJ7 Jeep CJ Forum 8 01-07-2010 12:37 AM
