converting my 78 CJ5 from steering column ignition switch to one mounted on the dash - JeepForum.com
post #1 of 3 Old 08-21-2013, 09:37 AM Thread Starter
ironcityal
1978 CJ5
I have a 1978 CJ5 looking to move my ignition switch from the steering column to one mounted on the dash and i need some help.
1. whose ignition switch and part number did you use?
2. what is the wiring diagram you used to hook up the new switch using the exsisting wiring? what color wire went on what post? Thanks in advance.
ironcityal is offline
post #2 of 3 Old 08-21-2013, 09:58 AM
jdarg
Pre '76 CJ's had a dash mounted ignition switch. You can find repros all over the place - Amazon, ebay, rockauto, etc.
'94 YJ - SBC/AX15/231, SOA, 8.8, 34" swampers
'06 LJ Rubicon - 31" ATs, OME 2.5", belly-up skid, other junk
'75 CJ5 - 232/T14/D20, 'glass tub w/ 2" BL, otherwise stock
jdarg is offline
post #3 of 3 Old 08-21-2013, 10:40 AM
WindKnot
1977 CJ7
All those questions are answered in the Factory Service Manual. Not a Haynes or Chilton. Those are too generic.
Factory Service Manuals can be pricey but they're very much worth the cost. Some are available on-line as well.
Try looking at the Morris 4X4 website around the bottom of their home page for "Jeep Resources" More than likely it will have a FSM for your year to browse. Nothing beats having the book in your hands though, full of notes to yourself on how you did things.
Looky here: http://www.jeep4x4center.com/knowledge-base/index.htm
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
