"Convertible" Lift Shackles 1 1/2" to 2"? - JeepForum.com
post #1 of 22 Old 10-08-2010, 02:11 PM Thread Starter
FamillyCJ7
1983 CJ7
I just came across this and haven't seen any like this before. Figure some people on here might be interested in it too because it's one shackle that has the ability to provide 2 different lifts. Many people here have the ability to make them their selves too.
"Bulletproof shackles"
Fits JEEP CJ-7 1976-1986
Convertable shackles
Why buy a 1 1/2 or a 2 inch set when you can have both ?
We have made or shackles so if you want a 1 1/2 inch lift now and get bigger tires later you simply move the bolts to the lower holes and now you have 2 inch lift shackles .
Its just that easy.
So you want 2 inch lift in the front and
1 1/2 lift in the rear....these are the shackles for you.
'83 CJ7 258I6 4-Speed Father Daughter Project - Using Monstaliner/Chassis Saver and Products from CrabTreeTool
NorthEastFL4x4.com - Local 4x4 Enthusiasts website, join up now!
FamillyCJ7 is offline
post #2 of 22 Old 10-08-2010, 02:18 PM
twoleos617
interesting to say the least.
first off, anything over an inch is too much.
deciding these "might come in handy" down the road, is just poor planning.
my .02
twoleos617 is offline
post #3 of 22 Old 10-08-2010, 02:29 PM Thread Starter
FamillyCJ7
1983 CJ7
Why is anything over an inch way to much?
post #4 of 22 Old 10-08-2010, 02:31 PM
Cherokee-at-16
thats nothing really NEW, i have a set from rough country that has 2 holes for 1.5-2 inches on my xj.
Cherokee-at-16 is offline
post #5 of 22 Old 10-08-2010, 02:49 PM Thread Starter
FamillyCJ7
1983 CJ7
Really... This is the first time I've seen them for CJ7's. Is there a reason why anything over 1" lift with shackles is bad?
post #6 of 22 Old 10-08-2010, 02:50 PM
D-BO
There is a general consensus that shackle lifts are not the proper way to add ride height. You can run a search on the forum and there are many discussions about why. However, it is a cheap way to get a little extra height to run some bigger tires, but it is not good on steering geometries and isn't really functional for off road use. I would compare it to a body lift... 1" has benefits but 2 or more causes weak points, stress points, and can get dangerous.
Whenever something breaks on my Cj... I learn something new by fixing it.
D-BO is offline
post #7 of 22 Old 10-08-2010, 02:59 PM Thread Starter
FamillyCJ7
1983 CJ7
I was planning on a 1" but possibly 1 1/2". Would the 1 1/2" be bad? I mean I got 4" lift springs, so if I did the 1 1/2 that would net 5 1/2" of lift. I don't want to run a body lift, wanting to run 33's and then maybe 35's in the future. With Tube Fenders up front, possibly the new metalcloaks available. Would 5" of lift be enough for 35's in the future?
post #8 of 22 Old 10-08-2010, 03:01 PM Thread Starter
FamillyCJ7
1983 CJ7
Or could it be possible to make instead of 1 1/2" to 2", make 3/8 to 1" lift shackles instead?
post #9 of 22 Old 10-08-2010, 03:03 PM
LSUtiger
1980 CJ5
If you get the hd shackles, they are 1/2 longer. Then a 1' body lift and you are set. To get 1 1/2" lift from shackles you would need a shackle that is 3" longer than stock.
1980 cj5 401, t-176, p/s., YJ p/b, tfi/hei hybrid, 3.73 30/44
LSUtiger is offline
post #10 of 22 Old 10-08-2010, 03:09 PM Thread Starter
FamillyCJ7
1983 CJ7
I don't like body lifts. But how about making a shackle like this but it being able to be a 3/8 or 1" lift.
post #11 of 22 Old 10-08-2010, 03:16 PM
CSP
Keep it under an inch and you're fine. Anything over that reduces the caster angle in the front axle to the point where wandering and the lack of return-to-center start to occur.
It's been posted many, many times here.
CSP is offline
post #12 of 22 Old 10-08-2010, 03:36 PM
tacjeep99
The other thing long shackles do is put extra leverage on the spring pack causing the springs to flatten out and stress. Additionally, over the long term, as the spring flattens out you lose whatever lift you originally gained.
Like one poster said, shackles in the 3/4" to 1" lift are probably the most you would want to go and not have problems.
tacjeep99 is offline
post #13 of 22 Old 10-08-2010, 03:50 PM
CjAl
1980 CJ7
for 1" lift the shackle needs to be 2" longer. Stock shackle is either 3 or 4"(cant remember but i'm leaning to 4" so a 2" lift shackle wold be 8" long. that's just STUPID!
you would never find a shackle more the 1" longer then stock on my jeep (1/2" lift)
CjAl is offline
post #14 of 22 Old 10-08-2010, 05:03 PM Thread Starter
FamillyCJ7
1983 CJ7
ok you guys got me convinced. Thanks for the information. I wasn't aware of that. I'll probaby go with HD shackles either the 3/8" lift or max of 1" lift. 5" of lift should be plenty to run 33's anyways.
post #15 of 22 Old 10-08-2010, 07:07 PM
gojeepin
1983 CJ7
Determining the needed shackle length isn't magic. Shackles need to be long enough to allow the spring to flatten or else the long leaf will abruptly stop or bend. They also shouldn't be longer than they need to be.
Vibration? Bump steer? Wandering? Read the article (sticky) on Steering, suspension, and driveline.
gojeepin is offline
Ugg! Rugged Ridge "stock" length shackles actually 3/8" lift 1984Laredo Jeep CJ Forum 16 12-26-2011 04:12 PM
no power coming out of the solenoid with the switch in the "start" or "on" positions SPless Jeep CJ Forum 5 07-13-2010 04:41 PM
Will a 4" trailmaster lift and a 2" body allow for 35" baja claws. yojeep79 Jeep CJ Forum 13 08-19-2009 08:20 PM
3" Black Diamond + Warrior 1 1/2" Lift Shackles sweetguardian00 Jeep CJ Forum 4 05-10-2008 04:15 AM
cj7 2" suspension lift with 32" or 33" tire pics? jojo99 Jeep CJ Forum 12 11-18-2007 10:40 PM
