contour fan writeup? - JeepForum.com
post #1 of 12 Old 12-30-2011, 05:50 PM Thread Starter
RockScar
I've searched here, pirate, and google, but I'm still stuck...
I'm looking for a link (or anything really) to a writeup or something laying out how to do the Contour fan swap. I'm out of the state and my brother in law is doing this for me, but I need something to get him going.
Also, which specific cars (year/engine) will he need to look for at the junkyard?
Thanks!
Live free or die. Death is not the worst of evils.
RockScar is offline
post #2 of 12 Old 12-30-2011, 06:26 PM
1984CJ
1984CJ's Avatar
http://www.cj-8.com/forum/showthread.php?t=24725
http://www.jeep-cj.com/forums/f2/contour-dual-fan-5169/
and
http://www.jeepforum.com/forum/f8/co...-fans-1247090/
Might also drop a line to VACJ7 since he originated one of those threads.
84 CJ7 258, T5, D300, AMC 20, D30 EZ lockers F&R
33" TSL, 2.5"BDS lift, .5" shackle lift 1" body lift
Originally Posted by ftdranger
You guys on the CJ tech page are a little to tech for me. Must be the leaf springs.
1984CJ is offline
post #3 of 12 Old 03-18-2012, 12:20 PM
ThisGuyUKnow
the link in post 2 at jeep-cj is my write up from a while back.
It is really not hard to do. You will need to source a contour fan, remove the four bolts holding on the manual fan, and either build brackets or use radiator straps to hold the fan in place. I suggest building brackets as the fans weight on those plastic straps can damage the radiator fins. If the four bolts holding the fan also mount the pulley onto the water pump you may need to source shorter bolts to bolt the pulley back up I can't remember.
I also suggest using this controller http://www.summitracing.com/parts/FLX-31165/ instead of the universal ones they sell at the parts houses because it works better and lasts longer.
Thats about everything if you have any more questions feel free to ask. Also you might want to consider if your alternator has enough oomph to handle the added amperage draw from 2 fans.
1985 CJ7 Laredo, 4.0, NV3550, D300, 3.31 AMC 20 w/trac loc
ThisGuyUKnow is offline
post #4 of 12 Old 03-18-2012, 03:02 PM
Exposed
Exposed's Avatar
1981 CJ5
I used the same contoller and works great... NO problems what so ever.. Send me your email and I will attach a PDF of my wiring of the controller.... I can't figure out how to attach a PDF....
Maybe will help...
Calvin
81 CJ5, Ford 331 EFI, AX15, D-300, Dana 44 (Detroit Locker)....
When there are more people voting for a living than working for a living,
We are DONE as a Country!!!!!!
Newly Acquired 2014 Grand Cherokee Summit
Exposed is offline
post #5 of 12 Old 03-18-2012, 05:10 PM
bentring
1976 CJ5
http://www.filedropper.com/ It's like photobucket for files. Just upload and post/pm a link.
bentring is offline
post #6 of 12 Old 03-18-2012, 05:22 PM
Coiz
1979 CJ7
They pretty much bolt right up.
How you want to wire it depends on if you want to use a controller, thermostatic switches, or a simple switch. Here is an example of how I wired mine with the standard Flex-A-Lite two fan controller. I added in a switch to manually turn them on, off or let the controller do it automatically with the thermistor probe in the radiator fins.
Mike
Coiz is offline
post #7 of 12 Old 03-18-2012, 08:12 PM Thread Starter
RockScar
Wow, I finished this awhile ago, but that's a great schematic for the controller. I'm planning to wire in an on/auto/off switch in, so I'll be back for that!
RockScar is offline
post #8 of 12 Old 03-18-2012, 11:16 PM
Coiz
1979 CJ7
I never noticed the original post date, just trying to help out. This might help someone else in the future doing a search.
If you're ever looking for a specific variance on wiring the fans, let me know what you're looking for as I am pretty good at working up specific schematics.
Mike
Coiz is offline
post #9 of 12 Old 03-19-2012, 03:50 AM
Exposed
Exposed's Avatar
1981 CJ5
Looks like Coiz beat me to the punch....
Calvin
Exposed is offline
post #10 of 12 Old 08-19-2012, 05:45 PM
turbogus
1978 CJ5
Since I'm only now doing this swap to cool down my 360 I've received a couple of "this thread is dead" notes, perhaps the moderator might consider collectively putting all the wiring diagram suggestions and other errata in a stickie?
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #11 of 12 Old 08-21-2012, 02:28 PM
turbogus
1978 CJ5
Okay gang, after being frustrated by failed attempts at getting part nos. I decided to go back to the boneyard and found these;
The text on the green one reads;
Ford C8F6A
93B6 8C616 AA
RELAT ASY.
ENG. COOL.
FAN CONTR.
12V-
[PA6-G30
The text on the normal sized one reads;
FORD G1UHD
93BG 14N089 CA
V23136-J4-X1
12V 70A
PA
Can anyone tell me if these are correct and what's up with the oversized green one?
turbogus is offline
post #12 of 12 Old 08-24-2012, 07:47 AM
turbogus
1978 CJ5
Sorry for my incessant posts folks, I will desist.
turbogus is offline
Need help with a Contour(?) fan upgrade Daladim Jeep CJ Forum 0 10-04-2010 08:38 PM
Contour Fan Measurements Daniel W Jeep CJ Forum 5 04-27-2010 03:22 PM
Contour Fan Set-up StewartCJ7 Jeep CJ Forum 8 01-06-2010 11:37 PM
Another Contour fan thread cj7kevin Jeep CJ Forum 4 05-17-2008 01:15 PM
Contour Fan How much did you spend? slacker92104 Jeep CJ Forum 23 05-02-2008 06:59 PM
