Contour Fan Set-up - JeepForum.com
post #1 of 9 Old 01-06-2010, 11:16 AM Thread Starter
StewartCJ7
1978 CJ7
Contour Fan Set-up
I have a 78CJ7 with a AMC360, I am in the process of installing the Contour Dual fan set-up. My question is, I want to do this on the cheep side. I really just want to wire it to a toggle switch that I turn on/off everytime I use the jeep. Do I need relays/controller or can I just direct wire everything??
Thanks
StewartCJ7 is offline
post #2 of 9 Old 01-06-2010, 11:29 AM
CSP
You need relays at the very least so that the fan gets the full amperage that it requires. You also don't want that much amperage going through your switch.
Relays aren't expensive at all.
CSP is offline
post #3 of 9 Old 01-06-2010, 12:57 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
The temp switch controllers can't be that bad either. less chance of forgetting to turn it on. Or just wire it to an ign power source thru a relay, so when the key is in 'Run' the fan is on. Less hassle, fewer switches to clutter dash.
Rick
Cutlass327 is offline
post #4 of 9 Old 01-06-2010, 01:15 PM
Area.3.Fiftyone
I would just buy the kit and be done with it.
I would not want to run that much amperage through a switch, and would not recommend manually operating the fan.
Running the fan all the time is not a good idea either by wiring it to the run position on the key.
You want the motor to have some heat in it or condensation will build up on the inside and destroy your motor and you'll have no heat in the winter.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #5 of 9 Old 01-06-2010, 07:24 PM
SpencerC
1978 CJ7
How many amps do the contour fans pull, together? I was looking at a fan control switch I found, its simple and easy and cheap. It has to be nothing fancy, the cj gets driven about once every 2 weeks, so this should do.
Only real questions I have is the setup has a AC override wire that goes to AC clutch. Any way I can wire this to a switch to force the fans to run? To ground or 12v?
2nd question, it also has an ignition cutoff switch, you wire it in so that it disables the system while cranking, what would I wire this to? The starter 12v?
This is the kit
AutoZone.com | | Cooling Fan Control | ELEC FAN CONTROL PUSH IN
Should work right?
'78 Jeep CJ-7 - 304/3 speed
SpencerC is offline
post #6 of 9 Old 01-06-2010, 07:53 PM
jscherb
Amperage and other specs for the Contour dual fan can be found here: 33212 Information
"Whether you think you can do something or you think you can't, you are right" - Henry Ford
jscherb is offline
post #7 of 9 Old 01-06-2010, 08:04 PM
SpencerC
1978 CJ7
Looks like they pull up to 34amps, not sure what the kit I found can handle, but it seems a few other people are using it, so I think(read hope) itl work for what little use it sees.
SpencerC is offline
post #8 of 9 Old 01-06-2010, 11:02 PM
HackFabrication
HackFabrication's Avatar
1976 CJ5
Or you could spend a bit more and get the FAL 31165
Flex-a-lite 31165 - Flex-a-lite Variable Speed Controllers - Overview - SummitRacing.com
"In the end...It's all Hack."
HackFabrication is offline
post #9 of 9 Old 01-06-2010, 11:37 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
If it is A/C controlled, then I'd 'guess' it to be 12v - it'd probably be spliced into the compressor clutch power.
Rick
Contour Fan. Factory speed control? slacker92104 Jeep CJ Forum 108 05-24-2013 07:20 AM
Wiring Fan (Ford Contour) stephens_cj5 Jeep CJ Forum 14 05-21-2012 01:05 PM
Another Contour fan question Jeepcat Jeep CJ Forum 1 07-16-2008 06:30 PM
Another Contour fan thread cj7kevin Jeep CJ Forum 4 05-17-2008 01:15 PM
Contour Fan How much did you spend? slacker92104 Jeep CJ Forum 23 05-02-2008 06:59 PM
