Connecting a Motorcraft 2150 Carb - Page 2 - JeepForum.com
post #16 of 29 Old 11-22-2013, 08:46 PM
86cj74.2L
86cj74.2L's Avatar
Start searching the Fourm for properly hooking up the electric choke through a oil pressure switch.
That electric choke will draw a constant 5 or so amps.
The ignition wiring is crappy at best. I don't know if putting a electric choke on the ignition circuit of something that wasn't sized for it if it will cause problems. Its easy to use the ignition circuit to energize a relay. And then use that relay to power the choke.
86cj74.2L is offline
post #17 of 29 Old 11-22-2013, 08:59 PM Thread Starter
El_Capitan
1978 CJ7
Also a good point. I was thinking to run it from the ignition, where my distributor lead is coming from.
I think I may actually wire in some sort of power and ground bars in the engine bay for all of these things that suddenly need power. First things first, get this sucker mounted and running.
El_Capitan is offline
post #18 of 29 Old 11-22-2013, 09:14 PM
JeepinEng
1979 CJ7
El_Capitan
Once you have your new carb up and running can you post an impression of how it's working for you. I've looked at getting a rebuilt 2150 from National Carbs and am interested in other people's experiances with them.
Thanks
JeepinEng is offline
post #19 of 29 Old 11-23-2013, 08:01 AM
hutch1200
Recovering Bronco Rider
hutch1200's Avatar
1979 CJ7
As far as the "Harley" breather is concerned, any FLAPS will have a similar 1.5" round filter. Usually cloth, K&N style. http://www.jpcycles.com/product/4300150
Is this what you had in mind 86cj74.2L? If so, I gave ya a thumbs up! Plus it's chrome! It is an aftermarket bit, so if you call a few Harley/ATV/Import shops etc, they may have one hanging on the wall for $20. Could have ya up & running today. Saturday is busy, so get to dialing!
I've also learned that sometimes... when people don't agree with you .... its best to hold them down and kidney punch them till they agree with you
hutch1200 is offline
post #20 of 29 Old 11-23-2013, 08:11 AM
86cj74.2L
86cj74.2L's Avatar
I paid a lot less than 20 for the breather on the sporty. Didn't say HD either.......
But yes that type is what I had in mind.
post #21 of 29 Old 11-23-2013, 08:14 AM Thread Starter
El_Capitan
1978 CJ7
Nice!
Though I just left the auto parts store,.and completely forgot about this.
post #22 of 29 Old 11-23-2013, 08:44 AM
hutch1200
hutch1200's Avatar
1979 CJ7
tax
I was just quoting J&P+tax/shipping if needed. Great minds etc........
post #23 of 29 Old 11-23-2013, 10:08 AM
86cj74.2L
86cj74.2L's Avatar
That's fine hutch. I did buy it at the HD dealer.
Since I'm at the gayarage
post #24 of 29 Old 11-23-2013, 10:42 AM Thread Starter
El_Capitan
1978 CJ7
Ok, got it connected and it fired right up. However it's running rich as all get out.
The mixture screws were 6-1/4 and 6-3/4 out from the shop, so I dialed them in to 3 out. I tried the mixture tuning trick of starting at 2.5 turns out and working them in till the idle went rough, then 3/4 out, but 3 seems to be where I end up anyway.
Still running rich and backfires through the carb if I let it idle the hit the gas.
A couple things here; My choke doesn't seem to be working at all. It just takes a 12v lead, right? I'm wondering if I don't need a male:male adaptor to connect it to the heater tube? I know you said that I can just plug that port, which I did, but curious why the butterflies aren't opening.
Second question; Do I need to plug the power valve into a vacuum? My old carb AL-2100 doesn't have that port. Could that be causing it to run rich?
Thanks, all!
post #25 of 29 Old 11-23-2013, 11:16 AM Thread Starter
El_Capitan
1978 CJ7
Ok, the backfire was timing. Fixed that, and plugged the vacuum advance into the carb base rather than the manifold. I know that they say to plug it into the manifold for an HEI setup, but I couldn't get the idle down that way.
The choke still doesn't seem like it's working, though.
Also, question still stands on the power valve.
I'm thinking the reason it seems to run rich is b\c I have NO emissions stuff connected whatsoever. That's another project in itself.
All in all, though it runs much better than it has since I've had it.
post #26 of 29 Old 11-24-2013, 08:03 AM Thread Starter
El_Capitan
1978 CJ7
Seems I'm still battling a timing issue. I took it for a test run yesterday and it ran better than ever. Let it sit for 10 minutes, then went for another drive and had a bad miss. Can't nail this down.
My only thought are the plus are gapped at .050, per hei recommendations. Too wide?
post #27 of 29 Old 11-24-2013, 08:37 AM
davegt
1983 CJ5
Where are you getting the power for your choke? It should only get power when the key is in the on position.
davegt is offline
post #28 of 29 Old 11-24-2013, 11:28 AM Thread Starter
El_Capitan
1978 CJ7
I tapped from the power lead to my hei.
post #29 of 29 Old 03-10-2014, 07:54 PM
oldiron4me
Gasket Stacking
On my J20..it is as follows for gaskets under carb... Thin gasket on intake, Hard plastic spacer/heat shield, then thick gasket, then carb. Hope that gets you going.
oldiron4me is offline
