Confused on center caps - JeepForum.com
post #1 of 9 Old 05-29-2008, 07:09 AM Thread Starter
slcom1983
Hi folks:
Although I have had tinkered with my 1978 CJ-7 for over 10 years in my garage, I have just decided to finally begin a "light" restoration. I though it would be wise to join the forum (so I suppose that makes me a newbie). I searched the archives for my first problem but can't find a solution. Maybe one of you has had experience with this. I want to bring the CJ-7 back to as close to original as possible, so I will start with the wheels. All the OEM 8 spoke have the JEEP center caps that are tapered, even the open one in the front for the lock out. My lockout open center cap is completely cylinderical (about 3 3/4) and is marked "Perfect Circle" on the twist lock. What was used in 1978? The steel chrome spoke wheels I have look original. Any ideas?
slcom1983 is offline
post #2 of 9 Old 05-29-2008, 07:12 AM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Any pics? You can sign up at photobucket.com and post links to the pics here
United States of America
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #3 of 9 Old 05-29-2008, 07:23 AM Thread Starter
slcom1983
Great idea. I just did that. The only picture I have is linked below. The resolution is very good so it can be zoomed very close to the front lockout. Hope this arrangement makes sense to someone. http://i282.photobucket.com/albums/k...1983/78CJ7.jpg
post #4 of 9 Old 05-29-2008, 07:37 AM
SlikRic
Muddin Maniac
SlikRic's Avatar
1983 CJ7
Very nice ride and welcome by the way. I'm no where near an expert, but the rims look original but the hubs look like they were swapped. I'm sure one of the many experts on hear can tell you for sure.
Born: July 4, 1776
Died: Nov 4, 2008
SUICIDE
SlikRic is offline
post #5 of 9 Old 05-29-2008, 09:12 AM
JoonHoss
2011 JK Wrangler
I'm almost certain that those are NOT original rims, just aftermarket '8-spokes'. hard to tell from that one pic.
factory rims have a rolled edge around the cutouts, and the caps screw on from behind.
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is offline
post #6 of 9 Old 05-29-2008, 10:47 AM Thread Starter
slcom1983
I think if I put original OEM 8 spoke wheels with the center caps on the back wheels they should work fine. But how could I use OEM 8 spoke on the front wheels with that cylinderical hub-lock and use the OEM open centercap? I am at work now but found a picture of the hub lock that are inside the cylinderical center cap that is there now. http://i282.photobucket.com/albums/k...circlehubs.jpg
post #7 of 9 Old 05-29-2008, 11:01 AM
JoonHoss
2011 JK Wrangler
most likely, yes, BUT, you need to know if they will fit.
that type of hub is very similar to another style called Selectro, where you can grab the entire assembly to turn and lock. I had those on my '57 CJ, and I fabbed a small handle that slid in each side of the hub to turn it inside the cab because i wanted to run full open caps up front. pretty simple.
FYI- you can also run factory caps with those rims, I think you just need to drill a couple of small holes to attched them. one of the members on here JUST posted pics a few days ago, I'll see if I can find the link, and you could PM him about the details.
the only other issue would be if it didn't physically fit in the opening
EDIT: here's the link, and upon closer inspection, I 'think' you'd need to go back to an orginal hub (or at least original sized hub)???
http://www.jeepforum.com/forum/f8/another-jeep-cj7-build-541569/
in any event, HTH
Hoss
JoonHoss is offline
post #8 of 9 Old 05-29-2008, 11:12 AM Thread Starter
slcom1983
Thanks...I'm learning more and more.
post #9 of 9 Old 05-29-2008, 11:59 AM
Mike Romain
The original CJ ones are fairly weak, I have blown out a bunch of them. Those sound aftermarket which will be a different size.
Your rims don't look stock, but if they are they will have 5 holes in them for the screws to come in from the back to hold the caps on.
Warn make a strong hub that will fit under the cap, but it has a round base. The stock one has a scalloped base to fit under the cap. The shop I bought mine from offered to machine the scallops into the warn one if I wanted, but I blew up the other side and blew the cap into bits so just gave up on them.
Mike
Mike Romain is offline
Help! Confused Bearing Caps. Need Advice! CJman77 Jeep CJ Forum 8 12-29-2009 08:08 PM
Modify Warn hubs to fit OEM center caps? idl Jeep CJ Forum 3 08-01-2009 08:32 PM
Center caps for original chrome Laredo wheels ryanburns22 Jeep CJ Forum 5 01-19-2007 08:10 PM
Center Caps or forget 'em jeepe Jeep CJ Forum 9 11-18-2005 08:02 PM
73 DJ5 gas caps uprailman Jeep CJ Forum 3 10-11-2005 11:11 AM
